Results 1 to 10 of 10
    May 2005
    SW Michigan
    Default Access the Shaft Log Packing Nut
    I have an 01 Outback LS that takes on water from the shaft thru hull area. I am wondering if anyone knows how to remove the floor panel above the shaft log packing nut to tighten it, as I'm guessing that this will solve the problem.
    Aug 2002
    Maryville, Tn.
    Default Replying to Topic 'Access the Shaft Log Packing Nut'
    You can contact; techservice@skierschoice.com. They will be able to assist you with both faxable and emailable (my own made up word), on how to render your situation. Brian Raymond
    Mar 2005
    t-town
    broncogeoff,
    brian had to help me witht his one.
    first remove the clam shell and set it aside. really fun when doing it on the lake. next there are two long screws at the corners of the floorboard. they are in the carpet so you just have to feel around and finally get them. just a word of advice, go ahead and buy extra #12 3 inch machine screws before you remove the old ones.
    good luck,
    doug, t-town
    May 2005
    SW Michigan
    Thanks for the quick replies. I will try pulling the floor panel today.
    May 2005
    SW Michigan
    Default Screws Removed, Panel Stuck
    After removing all the screws from the rear floor panel I am able to move it about a 1/2 inch before it seems to jam on the base of the rear seat. If I keep pulling it or moving it the base of the seat flexes and makes crackling noises. It appears that the carpet is what is catching. Are there any other fasteners or tricks to opening this panel? Do the exhaust hoses have to be removed from the engine? The packing gland is definately to source of water in my bilge so I need to get it tightened. Thanks for any help.
    Geoff
    Mar 2005
    t-town
    broncogeoff,
    were there only two screws close to the engine. i had to tilt the floor panel forward and then pull. mine seemed to stick to the carpet the first time but after that it was much easier. however i have to use a small hammer to push the panel back into place.
    let me know how it goes.
    doug
    Dec 2004
    Cinci-Dayton
    If it does not fit, force it - if it breaks, it needed replacing anyway!
    Naked red and white 2005 Moomba LSV
    Mar 2005
    t-town
    smokedog, great advice.
    i think that advice is what i used on my last prop.
    Feb 2003
    ISLAND LAKE IL
    besides sd2 advice, try to remove the seat base screws located on the left and right of the removeable panel. this will give you the needed play to remove the panel without damaging the seat base.
    chris
    CS
    May 2005
    SW Michigan
    Default Got It
    I got the panel out, thanks for the help. It just involved a lot of jimmying the floor panel and less direct pulling. I was able to tighten the packing nut and will be dropping it in the lake tomorrow to check that it stopped the water from flowing in. Thanks again.
    Geoff
  1. how to get to packing log
    By duckydave in forum Service & Repair
    Last Post: 05-31-2006, 09:58 PM
  2. Shaft packing - what size?
    By NH Moomba in forum Service & Repair
    Last Post: 04-26-2006, 07:35 PM
  3. Prop shaft packing adjustment?
    By james yarosz in forum Service & Repair
    Last Post: 06-15-2005, 05:32 AM
  4. Shaft Packing
    By qb12 in forum Service & Repair
    Last Post: 06-10-2005, 05:47 PM
  5. Shaft Seal Packing and Sealant
    By in forum Service & Repair
    Last Post: 06-23-2003, 07:42 PM
