Results 21 to 26 of 26
08-30-2011, 09:43 AM #21
08-30-2011, 09:49 AM #22Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
The Irritrol 700's in 3/4" are $20 something. The $54 should be the cost of the 1" 700 series valves. Go to www.sprinklerwarehouse.com and the prices should be close to this. Are you running 1" lines?
2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
08-30-2011, 09:49 AM #23
Here is that thread with the test results.
https://forum.moomba.com/showthread....light=IrritrolAl
08-30-2011, 10:03 AM #24Member
- Jul 2011
- Rapid City, SD
- 89
mnpracing You are correct, I was looking at the same site and the 1" valves. I need the 3/4" valves. Well played man. But after looking at the fill times, I may be better with my funds to add a T to the brass valve, add another pump and another intake on the manifold. That will probably be a winter project. For now I think i will use the RainBird valves I got an Menards to replace the worn out valves that are in there currently. Especially the one with a broken solenoid.
2013 Tige RZR w/ConvexVX, WetSounds Rev10s, 6x650s, Syn4 and Syn6 amps.
Surf Quiver 4x Brigade Wakesurfing Surf Boards- Aviator, Zulu, .352 Special, Bomber
Victoria Skim 2xGremlins, 2x Agents, 1 Factor, 1 Pixie Bri Chmel Pro Model
08-30-2011, 01:00 PM #25
I noticed reduced fill time with my 750 bag after I replaced the stock valve with the Irritrol. But, I would have two pumps running just to fill that bag through a single valve as soon as the center is filled.
08-30-2011, 02:10 PM #26
I was disappointed when I realized there was no improvement over stock with the Irritrol valves but after living with them for a while, I would still do it again.
I always encountered issues with the stock valves.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
