Results 1 to 3 of 3
    Feb 2003
    Maryville, TN
    Default ballast tubing size
    I'm customizing my ballast in my '01 Mobius. I was wondering if anybody knew the tube diameter for the stock ballast. I think its 1 inch but i'm not sure. Can anybody confirm the for me?
    Aug 2002
    Maryville, Tn.
    Default Tube size
    The hose diameter is 1 inch, the pump outlet is a little bigger, so you may have to heat that end of the hose with a heat gun and put on the pump while warm to have a good fit.Brian Raymond
    Feb 2003
    Maryville, TN
    Default inches
    For anybody else wanting to know, the "in" tubing is 1" ID, not sure what the OD is. and the "out" is 3/4" OD, probably 1/2" ID. found that out after I bought all one size tubing and nothing match with PVC connectors.
  1. Tubing off tower
    By Eric Z in forum General Chat
    Last Post: 03-25-2008, 01:44 AM
  2. Replies: 4
    Last Post: 03-03-2008, 06:12 PM
  3. Ballast tubing size?
    By iaonbb in forum General Chat
    Last Post: 06-12-2007, 07:53 PM
  4. Size of stock ballast
    By AZ_Calling in forum Wakeboarding | Wakeskating
    Last Post: 02-19-2006, 08:47 PM
  5. Size of LSV locker - for ballast
    By jchamlee in forum General Chat
    Last Post: 07-13-2004, 01:01 PM
