Results 1 to 7 of 7
Thread: 04 mobius lsv Fuel manager
08-23-2011, 09:00 PM #1Junior Member
- Aug 2011
- 1
Does anyone know what kind of fuel managers work the best on 04 mobius? i have 2 fuel lines, one going and 1 coming back to tank, so the Farias dont work.......grrrr.......after someone on the other end said it would!!!
08-24-2011, 11:45 AM #2
Why won't it work, it only needs to be connected to the fuel supply line feeding the engine to monitor fuel flow.
Kraig - 2010 Outback V
08-24-2011, 12:28 PM #3
I was told on a fuel injection system that both lines are monitored be aide one is a return for the fuel not burnt. If you just monitor the fuel goig to the motor and don't account for what is being returned to the tank then you would end up with a really high number. That is what was told when I looked into this.
08-24-2011, 01:14 PM #4
When I was looking to add a fuel monitor i had the same problem. You have a line sending fuel to the pump and then a return. So you have to have something to monitor the fuel going and coming to get a true gph. If you find something that works please post it up. I never had much luck.
08-24-2011, 09:10 PM #5
maybe moomba should go to a returnless fuel system!
08-25-2011, 01:29 PM #6Senior Member
- Apr 2010
- saskatchewan, canada
- 334
Why would anyone want to install one of these on a boat?
2017 Helix
Wakemakers 1050s
Bow bag ( Surf edition)
Autowake
08-25-2011, 10:19 PM #7
Best reason I can guess is because you can never trust the gas guage. There has been plenty of times that I have been on the lake and the guage has bounced between 1/4 and E so I got off the lake to find that I could only get 20 gallons in a 40 gallon tank. So I can off the lake at 1/2 tank because the guage showed I was empty. That's why I would guess.
