Thread: Slalom Course repair
08-23-2011, 12:27 AM #1
I have inherited an old Insta-slalom (I think) course. It needs some new PVC but it appears the stuff at Menards and Home Depot are all 1/8 inch wall, but in order for the 1-1/4 pipe to telescope inside the 1-1/2 inch pipe they need to be 1/16 inch walls. If anyone knows a source - besides Insta-slalom themselves, please let me know. TIA - DAVE
08-23-2011, 07:34 AM #2Senior Member
- Jan 2008
- Pensacola, FL
- 1,585
Sorry, I don't think you will ever get it to work right. However, if you ship it down to me in Tampa, I will ensure that it is repaired properly and used often; even in the winter.
1997 MasterCraft 205
2008 Moomba Outback
1999 MasterCraft Sportstar OB
1992 MasterCraft 205
1999 Malibu Response LX
1987 Marlin Magnum Skier
08-23-2011, 07:36 AM #3
Ya know I would - but I think it might dissolve in warm water ....
08-23-2011, 09:51 AM #4
When you're looking for pipe thickness you need to look for schedual 20, 40 or, 80. Go to a plumbing supply store and they should have what you need. Likely it will be sched 20 with that wall thickness.
PWI as usual...
08-23-2011, 05:58 PM #5
your in minnesota? you could try sps plumbing or indelco sp? both are in the st louis park area
http://www.indelco.com/pc-9264-329-s161.aspx
this looks to have less wall thickness than sch 40 pvcLast edited by c.rix; 08-23-2011 at 06:03 PM.
2007 Outback V
