Results 11 to 13 of 13
Thread: Trailer wheels bowing out?
09-21-2011, 12:07 PM #11
11-07-2020, 11:26 PM #12Junior Member
- Nov 2020
- 1
11-08-2020, 12:24 PM #13
On my last moomba trailer (2003 tandem axle) the front passenger side tire started to bow out and lean. The torsion axle most likely needs to be replaced.
In my experience I would address it now or you will have to fix it on the side of the road. The end result will be the bearings giving out and wheel coming off ruining the entire axle, calibers, tire, wheel, brake line etc... which happened to me on the way back from the lake. Not fun.
And when the bearing gives out it is not as simple as putting on the spare tire. I also experienced that getting a boat and trailer towed by a tow truck is not a easy task either. For the cost of having it towed you can replace the axle with a new one.
A new axle from boatmate is about $400-500 if I remember correctly. I would just contact boatmate and order a new one and swap it out if your comfortable doing it or have the shop do it.
On my 2019 moomba trailer the vault bearing oil leaked and went out and the wheel fell off and had same catastrophic effect. The trailer has been in the shop for about 6 weeks now and still waiting for boatmate warranty and the the shop to fix it.
Not to scare you but my advice is just fix it now when it is not an issue. It may save you a lot of headaches in the future.
Sent from my SM-G960U1 using Tapatalk- Jason
2019 Moomba Max
