Results 1 to 4 of 4
    Apr 2008
    Mid Michigan
    Default want help with factory stereo
    I have the factory set up with a kenwood unit, an amp other the seat and 6 kicker speakers. the set up is fine for what i do, but i would like to hard wire an ipod dock near the drivers seat to plug in an ipod and play music through the boat stereo, is that an option?
    is there an inexpensive set up to do what i want and where do i go to get one?
    Also, if i ever found a great deal on tower speakers, could my exisiting set up run them adequately?
    thanks
    As for the I Pod hook up i would talk with Al Cab he has a remote setup like the one your asking about.
    As for the towers no you will at least need another amp. 6 speakers in the cabin is about all that current amp will handle.
    Jan 2010
    North Texas
    Not sure which Kenwood unit you have, but I think most with ipod integration to the Factory Kenwood use this unit.
    http://www.sonicelectronix.com/item_...KCA-iP500.html
    This plugs into the back of the Kenwood HU and allows the HU to control the ipod once plugged in. It should list what it is compatible with.
    2006 Supra 20 - Sold
    2015 Supra SE450 - Sold
    Sep 2010
    Austin, TEXAS
    That's cool.. I think i have the 242 Kenwood unit, searching the internet for an aftermarket wired remote, not just the Jerry rigged Moomba wired remotes that work 50% of the time... the 107mr remote won't work with it I know.
    08 Outback. Private Lake Owner.
