Results 1 to 6 of 6
Thread: tower speakers
04-25-2005, 09:14 PM #1Junior Member
- Apr 2005
- 3
tower speakers
I have a 2003 mobius LSV. i'm thinking of getting some tower speakers + amp + maybe sub-woofer. my question is do i need to get a different or modify my bimini top or just not use it once i get tower speakers?
04-25-2005, 09:53 PM #2Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
Replying to Topic 'tower speakers'
I have not used mine yet but it looks like it just goes forward of the speakers
SD2Naked red and white 2005 Moomba LSV
04-25-2005, 11:10 PM #3Brian Raymond Guest
When useing the OEM speakers, you will be able to use the tower mounted bimini. Brian Raymond
04-26-2005, 12:12 PM #4
I just installed a pair of Fusion t-series tower speakers. They are not "huge" but I was concerned about the clearance. I'm careful when putting the top up as the fit is snug but they do clear without a problem.
I also found a post (I don't recall where) with instructions for shortening the bimini height. Someone pulled the plug at the end, took off an inch from the pole and simply reinserted the plug. According to them it worked just fine.
04-26-2005, 01:01 PM #5Senior Member
- Mar 2004
- Martinsville,Indiana
- 213
I have a pair of Klipsch SA-1 and use the bimini all the time.If you are doing the install,I found the easiest way to run the wires was to use the line from a weed eater to pull the wires down the tower tubes.
John
04-27-2005, 04:49 PM #6
I fed string into the top openning while a friend held a vaccuum cleaner "wand" at the lower opening. The vacuum pulled the string right to it; no fishing necessary.
Tower Speakers
By AZHeet in forum Boat OwnersReplies: 20Last Post: 03-24-2008, 09:48 PM -
Tower Speakers
By NateDog in forum General ChatReplies: 8Last Post: 03-05-2008, 12:55 PM -
Tower Speakers and Tower Lights
By BigRed0803 in forum Moomba ClassifiedsReplies: 5Last Post: 02-19-2006, 09:46 AM -
tower speakers ?
By lanceswake in forum General ChatReplies: 9Last Post: 01-26-2006, 09:45 PM -
Tower speakers
By atfloyd in forum Moomba ClassifiedsReplies: 1Last Post: 08-22-2005, 11:30 AM
