Results 1 to 10 of 11
Thread: Need a Bigger Surf Wake
08-14-2011, 09:30 PM #1Junior Member
- Mar 2010
- 27
We have 2001 Kamberra and want to spruce up the wake for surffing. Spent this past weekend on my buddies mobious and got some great surffing. noticed his boat had a wakeplate that looked a lot like a large trim tab. Does anyone know if or installed a lenco trim tab aftermarket?
08-15-2011, 05:24 AM #2Banned
- Jul 2011
- Clermont, Fl
- 104
Start on getting some ballast in you boat before worrying about wakeplates
See the classifieds - couple guys are selling 750 lb fly highs
my 2003 Outback had a big wave without a wakeplate
08-15-2011, 11:05 AM #3
You're in luck... We have the same hull.
https://forum.moomba.com/showthread....l-1-quot-lines
I have no wake plate either and not sure I could justify adding one. Adding weight and placement of it will get you to where you want to be.
If you want any help brainstorming, figuring things out, etc. just let me know. I went lots of rounds before I ended up with the above.So when is this "old enough to know better" supposed to kick in?
08-15-2011, 12:21 PM #4
I have an '00 Kamberra. Finally have my surfing wake "decent", and think I can get it better by doing a little more tweaking with what I've got. Not sure what you have for ballast terryleonard2000?
I have 750 in the right rear, 370 front center, 250 front right, 3 adult ladies on the right, and only ~50# in the left rear 250 bag.'00 Moomba Kamberra
'99 BMW 528it
08-15-2011, 03:27 PM #5
I surf with the wakeplate all the way up so it's not necessary for surfing, or wakeboarding for that matter.
Al
08-15-2011, 07:04 PM #6Junior Member
- Mar 2010
- 27
Thanks to all for the advice, gonna go the sacs route.
08-15-2011, 07:15 PM #7Junior Member
- Mar 2010
- 27
are you using a tsumi (sp) pump? I have heard they are pretty fast for filling and dumping. I like your set up suggestions, I am leaning toward a 750 sac in the center ski locker and an 1100 sac on the right rear beside the v-drive. I really can't afford to give up much more room than that with my 3 boys and all their boards. Whats your opinion on the 750 in the center versus the 370 center and 250 front right you have?
08-16-2011, 11:56 AM #8
No, mine take forever to fill with a single Rule filling all of them. it was already on the boat and have other upgrades that i want to do first...
I'm going to try to ditch the 370 in the locker and go for a 750. I'm not sure if it'll be too much weight up front for surfing though....I think it'll help wakeboarding, but again, not sure about surfing. Can't hurt to have a bigger one and partially fill it though. Still need the 250 on the right up front to try weighing down the right side of the boat. You can try the 1100 in the right rear, but I dont' think it'll fit. the 750 fills the space perfect. i dunno if it is ouir hull or what, but it seems like i really need a LOT of weight on just the right side.
You really oughtta jump on the 2 750# bags in the classifieds for $200+shipping from mmandaley! I wish I had the cash. Also if you hurry, you can get other stuff you need in the group buy! 25% off is HUGE!
As for space concerns, my 8th child is on the way, so i know all about a packed boat 100% of the time'00 Moomba Kamberra
'99 BMW 528it
08-16-2011, 12:14 PM #9
If you guys have the basement (belly) storage under the walkway up to the front playpen like I do the 750 fits in there beautifully and will fill 99% full. Also I don't think that is too much weight. I've ran around with the 750 in the basement filled, even pulled tubers with it still full, no issues. Having that full plus another 400+ up front or 2-3 passengers up there and you're getting into the light dunking of the front end territory.
I was disappointed with the wave from a 750 in the rear locker. The 1100 made a huge difference IMO. Catch is my lockers, and I'm guessing yours too, measure around 42-44" long and both the 750 and 1100 are 50" long so they'll have to bunch up on the ends. Especially if your battery/batteries are still back there.
My alternative idea for a faster fill and drain setup without going the fully auto, multiple pump setup was to go with 2 of the Tsunami 1200 handheld pumps. For filling the 1100 on the surf side, hook up both pumps to the top ports of the bag. You may have to stop one and do some venting along the way but that should fill and drain quick! Or you could run one handheld to drain the 750 while the other is working on the 1100, etc. You get the idea.
You can buy the handheld T1200s ready to go for $99 or if you were willing to add your own plumbing and 12v plugs/wiring you could probably put two together for around $120.So when is this "old enough to know better" supposed to kick in?
08-16-2011, 12:23 PM #10
thanks for the info berg.
I've measured the center and yes, the 750 would fit perfect there. The ~1100# Gravity Games bag would fit even more perfect, but to me isn't worth the $300 Still watching for a used one...
our rear lockers are plenty long for the 50" bag. It is the height and width that kills it. My width is about 22" towards the top and about 20" at the bottom, and the height under the gunwhale is 20". the 750# is 50x20x20, and really does fit perfect. It sits on top of my battery but doesn't hurt anything since i have the battery cover on it. I think the 1100# bag for the rear is 50x24x24, so it can't fill much over the 750 bag anyways...'00 Moomba Kamberra
'99 BMW 528it
