Results 1 to 6 of 6
Thread: Hydraulic Wedge Issues
08-11-2011, 08:45 PM #1Junior Member
- Aug 2011
- 3
Have 08' LSV and wedge doesnt move when I trim up or down. The solenoid makes noise but nothing happening in the back. Any suggestions?
08-11-2011, 10:05 PM #2
Check to see if there is hydraulic fluid in the tank. The tank might be located in the engine compartment
08-12-2011, 09:28 AM #3
trim resivor is is at your lower right hand side of the of the engine bay when your in the boat opening the engine bay door. Its a smaked plastic box. You can check the level of fluid there. If its low then you can add fluid, trans fluid i think but id look in the owners manual as i cant recall. Then you might need to actuate the plate up and down several times to bleed the air out of the system. Id also follow the tubes to see if there is a leak anyplace.
[COLOR="#696969"]
08-13-2011, 05:44 PM #4Member
- Jun 2007
- Monroe, LA
- 30
ATF fluid is what to use. My trim tank is on the forward port-side of the engine compartment.
2007 Outback V
Moon Lake
Monroe, LA
08-13-2011, 06:39 PM #5Junior Member
- Aug 2011
- 11
hello, check your fluid _sounds like its low.
08-14-2011, 02:45 PM #6Banned
- Oct 2005
- Durham, NC
- 649
You have a wedge? It sounds like you are on the wrong forum, bro!
