Results 1 to 7 of 7
Thread: Ballast bag = air bag?
07-27-2011, 08:33 AM #1Junior Member
- Jun 2011
- Lake Lanier, GA
- 18
On my 07 LSV, stock gravity 3 ballast, when I fill the center bag, it fills more with air than water, and starts pushing open the ski locker door well before it is filled. Kinda like a balloon... Is there a way to bleed the air out and let the bag fill 100% with water instead of what feels like half air/half water?
I'm sure there is a simple solution for this, but I have yet to figure it out.
07-27-2011, 10:02 AM #2
If you trailer you're boat like I do just remember to unclip the fill line from the ski locker bag before you leave the ramp. I do this every time now and it stays completely flat, if I forget it fills with air like a balloon. I thought about venting the bag but this is much easier.
-2012 Supra Launch 21V
-2008 Mobius LSV
07-27-2011, 08:10 PM #3
you can also close the thru hull ball valve
07-27-2011, 08:11 PM #4
or put a cork in the drain thru hull when towing on the side of the boat-thats where the air gets in at
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
07-27-2011, 10:08 PM #5Senior Member
- Aug 2008
- Cottage Grove, MN
- 780
if you have a third port on your bag, I'd put in a vent line. Some of the stock center bags don't come with a third port though.
2006 Outback V - Gone
2008 LSV - Gone
2013 other brand
07-28-2011, 09:02 AM #6
I had this problem in 09 when we got the boat, most of the air does come threw the drain port. The best solution is if you have the 3 plug in the bag vent the top plug back down to the drain line and T it together. It will then push the air out the drain side till its full of water.
I tried taping the drain hole, i even put a valve in it.
The second issue is then the turn the bag on the line from the Solinoid at the rear of the boat to the bag has a lot of air in it and will pump all that air right into the bag.
Venting it is the only real cure.
You can also get a 1 way check valve threw WakeMakers for the drain and then air cant come threw the drain port.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
07-28-2011, 09:44 AM #7
I unplug the fill line on my bags generally. They stay flat, just like bzubke said.
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
