Results 1 to 6 of 6
Thread: Service and Maintenance
07-18-2011, 09:38 PM #1
I'm trying to do my own maintenance on my boat. I have a 2006 Moomba Mobius. But there are a few things on the Maintenance chart that I do not fully understand what they are. The items in question are.
Clean Crankcase Ventilation System - Not sure exactly what looking for.
Clean Transmission Oil Strainer Screen - Not sure where this is located and what I'm suppose to do with the screen to clean it.
Lubricate Distributor Cam - I know where the distributor is but don't know what I am lubricating and with what I am to lubricate it with.
Lubricate Throttle and Shift Linkage Pivot Points - What are we lubricating and with what?
Lubricate Rudder Port - Not sure what I'm lubricating here either. Am I looking for a grease fitting to grease or just spraying lub on something.
Any help is appreciated.2006 Mobius LSV
07-18-2011, 10:36 PM #2
there is a how to for the trans screen.......its usu tight on a dd but def doable without pulling the engine
09 21v LAUNCH
99 Outback LS. Sold
Doug
07-19-2011, 06:48 AM #3
Is the transmission oil screen the little plate on the bottom of the transmission that has the little filter?
07-19-2011, 09:05 AM #4
Walb0244, here's a thread that may be helpful.
https://forum.moomba.com/showthread....=100hr+service
That trans screen/filter is a pain in the shoulder to get to on my LSV but its doable.
PWI as usual...
07-25-2011, 10:25 PM #5Banned
- Oct 2005
- Durham, NC
- 649
Crankcase Ventilation: There is usually a PCV system similar to a car on our engines. Mine is a PCV valve on the valve cover (which you can clean or just replace) with a hose leading to the spark arrestor. The hose could probably be checked for blockage.
Transmission Oil Screen: Yes, there is a small plate on the bottom with the cylindrical metal screen inside. This is pretty aggravating to get to.
Distributor cam: Not sure about this one, but maybe this is talking about the rotor button inside the distributor.
Linkage: This is just the linkage rod right at the engine and/or throttle body. I think the manual says some sort of spray oil, but I have also heard of using 30 weight motor oil.
Rudder Port: Yes, there is a grease fitting on the top side of the rudder fitting down insdie the bilge.
I hope this helps some.
07-26-2011, 12:05 PM #6
Thank you. That does help. I will check these things out now that I know how what I'm looking for.
