Results 1 to 8 of 8
07-10-2011, 11:55 PM #1
Trailer Brakes heat up sometimes.
Just recently the brakes on my trailer have been heating up. It's all four of them at once. Today when I got the the ramp they were scortching hot but on the ride home i felt them every few miles and they never got hot. Earlier this week I noticed they were really hot at the gas station and by the time I got to the ramp(20 mi.) they were cool again. I've already replaced or rebuild all four calipers on the trailer so I'm leaning towards something in the actuator being messed up. Or possibly air in the system becuase I changed the last bad caliper out myself and could have not bled the system good enough. Has anyone else had this problem or have any insight to what the problem could be.
-2012 Supra Launch 21V
-2008 Mobius LSV
07-11-2011, 02:32 AM #2
I would definitely try bleeding the brakes again, any trappedf air will heat up and expand pressuring up the hydraulics and engaging the brakes.
2006 Mobius LSV 325 hp MPI Indmar
2005 6L Silverado 1500HD Quadrasteer
MODS: Polk DB651's Cabin Speakers, 10" Polk MM1040 Sub in a custom sub box, Kicker ZXM700.5 5 channel Amp, EZ net cargo nets, ACME 1847 Prop, 4 outlet Heatercraft Heater
07-18-2011, 02:37 PM #3
So all the brakes locked up on me again yesterday. When I stopped to check on them the pushord that you push in and out when you bleed the brakes was stuck, as in I couldnt push it in and it wouldnt come out. I pulled the truck forward and back a couple times and then it worked completely fine, the pushrod would move freely and didnt have any problems the rest of the day. I still havent tried bleeding the brakes but I will soon. Should I try and lube up the pushrod?
-2008 Mobius LSV
05-28-2012, 07:57 PM #4Junior Member
- Mar 2012
- 3
Did you fix your problem? Yesterday pulling the boat to the lake both rear brakes started smoking. Let it cool off, made sure the brake release tab was pushed, and then continued to the lake and the brakes weren't hot at all. Coming home, the brakes were also fine and not hot.
Any ideas?
05-28-2012, 08:29 PM #5
Never figured anything out before we traded the boat in. It had to have been something within the actuator that was getting stuck.
-2008 Mobius LSV
07-08-2012, 05:02 PM #6Junior Member
- Jun 2012
- 5
I am having the same problem. My brakes keep locking up. Where is the brake release tab? Also I was told I needed a five prong electrical hook up not the standard 4 prong. Any truth to this fixing my problem?
07-08-2012, 05:19 PM #7
When your brakes lock up, which direction are you going? So you are running a 4-prog into the 5-prong trailer connector?
Kraig - 2010 Outback V
07-08-2012, 09:48 PM #8Junior Member
- Jun 2012
- 5
Both fwd and rev. Yes was using a 4 prong. I see from others that I need the 5 prong adapter. Thanks all!
