Thread: phase 5 surfboard repair
07-03-2011, 10:59 PM #1
whats the best way to repair the top layer on a phase 5 board. the hard enamel chipped away at the nose and on the side.i think one of my kids dropped it. it is thier board though
07-03-2011, 11:15 PM #2
My kiddos knocked over my Inland Surfer and left a crack in the epoxy. IS sells a repair kit that color matches the epoxy and sandpaper (4 or 5 grades, end with a light wet sanding) to smooth it all out.
07-04-2011, 03:37 PM #3Senior Member
- May 2010
- Muskoka, Ontario
- 427
I just fixes my inland surfer. Got the repair kit from IS but you can always use GOOP marine fix fast epoxy. Same thing in 2 containers, just mix and in 5 min it's hard. Also put a piece of plastic from a sandwidge bag down on the epoxy when done and smooth it out. When it dries just peel away and no sanding needed.
I sanded mine to cut it down a bit than polished it with my porter cable, smooth as a babies..... You know
07-04-2011, 04:30 PM #4
my broadcast and is 4-skim have repairs with the epoxy. don't look pretty, but work
