Results 1 to 6 of 6
07-01-2011, 12:44 AM #1
Is this normal? Water coming out drive shaft.
At the base of the hull. I successfully installed my flush kit and gave it a go in the drive way. No problems, no leaks and engine never over heated. However, I noticed that there is a fair amount of water coming out of the drive shaft on the bottom of boat from the V-drive. Bilge is dry.
07 Outback V
Replicants are like any other machine - they're either a benefit or a hazard. If they're a benefit, it's not my problem.
07-01-2011, 01:05 AM #2
the water is to cool the packing
07-01-2011, 02:12 AM #3
Perfectly normal. Your boat has a dripless seal so water is routed to it to lubricate the seal and exits out the boat instead of the old style that drips into the boat.
Al
07-01-2011, 02:18 AM #407 Outback V
07-01-2011, 02:44 PM #5
Perfectly normal. You can put a shutoff valve inline on the dripless water line if running anti-freeze through your motor during winterizing. A couple of us have done that!
I freaked out the first time I saw it too
2015 "NOT A MOOMBA"
Why Not? Play Hard! Get wet
07-01-2011, 10:34 PM #6
Replicant - Here's the shutoff valve (blue coolant line) to which Viking makes reference. Easy install using plumbing pieces from Home Depot. When I winterize, the valve is shut so no antifreeze gets wasted spilling on the ground. - Deerfield
2007 Outback - SOLD June 2016
2012 RAM Crew Cab
2015 Subaru Forester
Stuart
