Results 1 to 10 of 15
06-29-2011, 11:06 PM #1
Rattle when the boat is idle?? Please help!!
I noticed a rattle today at the lake when the boat was just ideling? It seemed to come from the rear of the boat. When I put it into gear it starts to go away. When I pick up a little speed it goes away. The boat seems to run fine. It almost sounds like something is loose? Any body have any ideas?
2004 Mobius LSV
06-29-2011, 11:40 PM #2Member
- Jul 2010
- Deep River Ont
- 83
I guess it could be a number of things...it is a rattle, or an intermittent sound kinda in tune with the motor, like puck, puck, puck for lack of a better descriptor.....if so, have a look around the exhaust manifold for any drips or leaks. this happened to me and it was a failed manifold gasket at one port ( 4 ports on each side) probably not, but something to look at anyway
2008 xlv gg 340hp
06-30-2011, 12:08 AM #3
Could be low on ice and the cans and bottles are bumping into each other.
06-30-2011, 12:55 AM #4
No its more of a rattle that will speed up and slow down. Like something were to be coming loose.
I checked the cooler already and it was not that lol!!2004 Mobius LSV
06-30-2011, 01:03 AM #5
check your alternator to make sure the bolts are tight. otherwise listen and try to pin point it , have someone else drive
09 21v LAUNCH
99 Outback LS. Sold
Doug
06-30-2011, 07:40 AM #6
Swim platform? Mine did it at idle. When it's doing it stand on the platform. Just what I had with mine.
Share The Water
2006 Outback V
06-30-2011, 07:57 AM #7
Just get it fixed before July 15!
06-30-2011, 07:00 PM #8
Well looks like I have a another wedding on the 15th and some continuing education on the 16th but I think we will make Sunday. Looking at the noise this evening!!!!
2004 Mobius LSV
06-30-2011, 07:23 PM #9
Well that did not go well!! Couple of things-- I think the raddle is coming from the rudder!! I can get under the boat and move it real easy! Is that normal? Also I found I huge hole in the bottom of the hole. It's through the gel coat and into the fiberglass! Is that something I can fix or will I need to have someone else do that? I have no idea where it came from. Any help would be awesome!
If it's not one thing it's another.2004 Mobius LSV
06-30-2011, 08:39 PM #10David
