Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    now i am on a mission.
    Dec 2006
    Tigard, Oregon
    Joe, I used 4 wire security cable bought at Home Depot (it's all in one sheath) to run from the wiring harness under the dash to the transom remote.
    Al
  3. #13
    is the extension cable only the remote or if i cut it will there be 4 wires in.
    Dec 2006
    Tigard, Oregon
    The white wire with the blue stripe in your pic? That is a single conductor.
    Al
  5. #15
    Yes, the blue white one in the pic. Do the non lighted ones have 4 wires or just the one ( the current stock one in the boat)
    Dec 2006
    Tigard, Oregon
    I don't know as both mine are lighted.
    Al
  7. #17
    Thanks, I will check tomorrow and report back
    Al, again thanks for all your knowledge
    Dec 2006
    Tigard, Oregon
    I'm guessing the non lighted ones are three wire - power, ground, signal. It won't have the 4th wire which would be connected to a switch to turn the backlight on and off.
    Al
  9. #19
    so this extension cable is just for the signal.
    http://shopmarineelectronics.com/mar...0_00018_20.htm
    If it is what a racket from Lafayette radio....
    Dec 2006
    Tigard, Oregon
    Yup.. Just 20' of light gauge wire with the correct quick connect terminals on each end.
    Al
