    Jun 2002
    La Grange Park, IL
    Default Navagation and aft light issue
    Ran into an unusual problem yesterday. The Nav and aft light are on the same switch. Usually you can turn on the nav (bow) and panel alone, or select the switch to use nav and stern light. Yesterday it was nav and panel or just stern light. Both went on, just not at teh same time. Any suggestions?
    Fins to the left.
    2002 Outback LS
    Sounds like a three position switch where one or more of the positions has corrosion or a drop of moisture in there. I'd try removing it and cleaning the contacts before anything else.
    Feb 2010
    Canton, Ga / Lake Lanier
    Removing that switch is a HUGE PITA in my opinion...I broke mine trying to get it out when I was installing my LEDs.
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
    Well, you could try blowing some air into it and turning it off an on 50 times to see if it cleans up.
