Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    Looking good! What's the gph rating of the pumps?
    720 gph
    http://www.wakemakers.com/johnson-ul...last-pump.html
    Dec 2006
    Tigard, Oregon
    Thanks Joe. So for fastest fill times, looks like the Tsunami T1200 is still the way to go.
    Al
  3. #23
    Jun 2009
    Victoria BC Canada
    I guess that would depend on if you have enough room for them below the waterline. In my case I do not and those pumps are not self priming.
    2007 Outback V
  4. #24
    I installed the Johnson pumps this spring and it has worked well with my 1100lb sac's.
    07 LSV
  5. #25
    Sep 2006
    Beavercreek, OH
    Here is the over the top writeup: http://customfalconballast.blogspot.com/
    and another one (has a link in it about someone who tested Actual Flow Rates of aerator and impeller pumps):
    http://centurionavalancheballastinstall.blogspot.com/
    FYI, the mayfair aerator pumps really do need to be below the waterline to prime (scupper and moving forward is a good way to prime if mounted high). 1200gph is good, but Duffy who is a big surfer on WW, just put a manifold system and Rule 3800 aerator pumps in. He went with 1.5" throughulls. He's filling about 1800lbs in 4 minutes.
    Last edited by sailing217; 06-23-2011 at 10:22 AM. Reason: to tell about link about flow rate testing
  6. #26
    Oct 2013
    Ft. Collins, CO
    Quote Originally Posted by sailing217 View Post
    I had to register with on the CenturionCrew forum just to read the referenced post, which had some really good data. I posted the important part of it here: https://forum.moomba.com/showthread....104#post232104
    1989 Sanger Skier DX - sold
