Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Default Replacing mufflers with straight pipes.
    2001 Moomba Mobius. All measurements, parts, and pictures are based on this boat. Your boat may vary. I had to split this up into several post to get all the picture in. You can see my pics at:
    http://s277.photobucket.com/albums/k...flyboy/Moomba/
    I noticed my muffler was leaking, and after looking at how poorly they are constructed, I decided to simplify the exhaust by replacing the muffler with a straight pipe. There should not be any issues with the performance of the motor. In fact, I might gain a couple of HP as the exhaust is now more free flowing. The only thing to consider is an increase in exhaust noise. For me, I like my carbon footprint to be loud! Plus, with all the music coming out of the boat, motor noise is my last concern.
    My exhaust exits the manifold and enters the muffler at 3 1/2" I.D., then exits the muffler at 3" I.D. This 3" line then continues to the exhaust exit at the back of the boat.
    Through eBay, I found Ashland Muffler House, Inc.
    http://www.ashlandmufflerhouse.com/
    For about $60: They sold me a 5' piece of 409 stainless 3" O.D. tubing. Cut it in half. Put a 30 degree bend at the end of each 30" pipe, leaving 4" of straight pipe. Here, you can see the pipes, placed next to the mufflers:
    HINDSIGHT: If I'd known that I was reducing from 3 1/2" to 3", I would have asked them if they could flange the short end to 3 1/2", saving me the headache of sleaving the small pipe to fit into the large one. I'd also have them bend the tube to 45 degrees.
    This is a picture of the pipes inserted into the large rubber exhaust:
    In this configuration, the tail of the SS pipe, overlapped the 3" rubber by 7":
    Since I'm not going back to the mufflers, I cut off 3 1/2" of this rubber exhaust to use as a sleave for fitting into the larger rubber pipe at the manifold. I used the clamps as a guide to cut. I then inserted the short end of the pipe into the sleave, giving me a perfect 3 1/2" O.D.
    Default Page 2
    I lubed everything up with a lot of WD40, inserted the 3" end into the 3" rubber, and then muscled the sleaved 3 1/2" end into the 3 1/2" rubber:
    Default Page 3
    Clamped everything down:
    I went to the boat ramp and checked for leaks. At the lower RPMs, I did not notice much more noise. The installation was clean and simple.
    Afterwards, I used the old muffler clamps to secure the exhaust. I was also careful to route and zip tie all electrical wires, hoses, or anything else that could melt well away from the SS pipe. It will be hotter than the mufflers.
    Default Page 4
    Addtionally, I replaced the the shaft log and repacked the gland nut. To do this, I had to remove the prop shaft flange. I simply put a socket between the flange and the transmission, tightened the bolts, and it popped loose very easily:
    Default Page 5
    Here's a picture of all the parts cleaned up and ready for assemble. NOTE: I was only able to use two of the packings.
    I'll let you know what the noise level is like once the winds calm down and I get on the lake. I'm really not worried about it.
    Jimmy
    KISS: Keep It Simple Stupid
    Aug 2009
    Montana
    definitely post up some video with the sound of that when you are done if you can
    2015 "NOT A MOOMBA"
    Sep 2009
    Grayson, Georgia
    This is rad.
    I can't wait to hear the sound.
    Good job sir!
    -Mark
    2005 LSV
    Tow w/:
    Volkswagen Touareg V8
    -John Wooden
    Excellent post and pics.......curious ...why did you replace the whole packing gland and not just the packing material, you would not have to remove the coupler and everything?
    oh and I would put some anti rust stuff on your motor mounts , they are pretty rusted.....and maybe check your alignment if you didn't>.......jmo
    99 Outback LS. Sold
    i talked to the owner of a local boat repair shop today known as water junkies about the alignment. he acted like i was stupid for worrying about it. basically said "did you hit anything" and i said no, and then he said "well then why are you worried about it?"
    i could not get my engine to move to the right to close the gap so it will stay at .017.
    I didn't replace the hardware, just cleaned it up.
