    Oct 2009
    Tumwater, WA
    Default Prop removal tool ???
    What should I buy at home depot or lowes that I can use in replacement of the prop puller. I got a new prop but can't get the old one off. I don't have a torch either.
    2006 Outback V, Alpine CDA-118M, 2 alpine MC20's, Polk Cabins, 2 Exile XM7s 2 SXT65s (tower), Memphis Mojo 12" Sub in custom downfiring ported box, Kicker 2500.1, Exile Harpoon, JL M6450, WS-420.
    Acme 1433, 750lbs Sacs in Rear, GG 1180 (fills to about 700) Sac in Center Locker, 650 lbs Nose bag.
    PP Stargazer
    Tooele UT....
    go to harbor freight and buy a set of 3 2-sided pullers. they are around $15 and are only sold in a set of 3. make sure and get just the 2-arm, not the 3-arm.
    the 2arms will fit around the 4blade props. it's tight, but I've taken mine off twice with them..
    Sep 2010
    Lake wallenpaupack PA
    Check sears as well they have 2 and 3 arm pullers
    Aug 2006
    took mine off last night..
    3 tools..
    5" C clamp
    hammer
    Adj Crescent wrench
    a 2x4 to hold prop from spinning while loosening prop shaft nut
    loosen bolt on prop half way off (NOT ALL THE Way as you need it to catch prop)
    Take crescent wrench and open enough to fit around shaft Behind prop. tighten back up
    Take C Clamp and put bottom end on end of shaft and threaded end onto crescent wrench...
    tighten up snugly....
    Take hammer and tap on end of thread shaft of C Clamp... should pop loose...
    worked for me last night..
    although I suspect the 3 claw pullers up above would help as well!
    Brad
    Mississippi/Louisiana
    2011 Launch 21V
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    Oct 2009
    Tumwater, WA
    Sandm, Thanks!! That worked perfect.
    PP Stargazer
