Results 1 to 6 of 6
Thread: Squeal on start
06-16-2011, 03:57 PM #1Senior Member
- Jul 2010
- Northern VA
- 132
Squeal on start
So the Moomba has been squealing when starting it the first time each day - now it happens pretty regularly although not always. Lasts maybe 30 secs to a min. Only happens on the first start each day when putting the boat in, each start afterwards is fine, even after floating for a while. I take the boat out of the water each day. It's the 325, got about 80 hours - bought new end of last August. Thoughts? It's starting to drive me crazy. Doesn't seem to matter whether kept inside or outside overnight it still does it the next morning. I can't figure out what's different about why it does it sometimes and why not, and lately it's been always doing it
2010 LSV
06-16-2011, 04:14 PM #2Member
- Sep 2010
- 40
Could be your belt....
06-16-2011, 04:53 PM #3
id bet its the alternator belt, once its warm it stops and then it fine all day till you park it over night again.
[COLOR="#696969"]
06-16-2011, 05:27 PM #4Senior Member
- Jul 2010
- Northern VA
- 132
how do i make it stop?
2010 LSV
06-16-2011, 10:56 PM #5
tighten the belt by shifting the alternator.....there may be a flat spot on your belt and it may need replacing....how may hours and years are on the belt? there should be about a 1/2" up n down play on the belt
09 21v LAUNCH
99 Outback LS. Sold
Doug
06-17-2011, 08:46 AM #6
Since your a 2010 boat take it back to the dealer if hes close by. Other wise on the ALternator braket there should be a square hole to put a ratchet in and add pressure to it.
Other wise loosen the mounting bolts and grab a pry bar, not a huge one just one long enough to give you leverage.
Make sure you prying against something strong like the engine block or something metel thats not an engine component like a starter or pump of some sort. Then add pressure to the alterntor case to tighten then belt. The with your free hand tighten the bolts in the alternator. Done.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
