Results 1 to 10 of 11
    Sep 2009
    Copperas Cove, TX
    Default Helped a stranded Moomba owner tonight
    My lady friend and I were on our boat in an area known as "the alley" where most wakeboats go. It was only us, one damn tuber, and a Moomba LSV. The Moomba had been surfing for almost two hours straight...pull after pull. We saw them just outside "the alley" floating for a bit. After a while we decided to drain our ballast and head in since it was almost sunset. I looked over my shoulder and saw the Moomba being towed by a Bass Tracker boat. I pulled up closer to them and saw the boat was pre-2009 or 2010 so I asked if the boat would crank. The guy said yes and that they had plenty of gas. I asked them if they had cold water on board and which point the wife holds up one of those 2 gallon thermos jugs. I stayed in my boat but directed him to the fuel pump and told his wife to pour the cold water on it slowly for a few minutes. We waited 10 min and chatted and then the boat fired right up. Nice to help a stranded boater without having to tow them.
    Aug 2010
    Acworth, GA
    Well Done Sir, Well Done Indeed!!
    Kraig - 2010 Outback V
    Sep 2006
    Beavercreek, OH
    Good karma. Have a good season
    May 2011
    Fargo North Dakota
    Default fuel pump
    Ok so whats the deal with these fuel pumps? They heating up and vapor locking? Where on my 05 LSV is it located?
    2005 Moomba Outback
    Sep 2009
    Medicine hat Alberta
    Great call. I don't know where yours is I have a new one and shouldn't have this problem but I have heard of it alot.
    2010 möbius ls "you ain't fallin you ain't learning"
    ok so far i have never had this issue but just in case i do run into it one day. where is the fuel pump on my 08? i would think it would be in the gas tank which would make pouring water on it somewhat difficult
    Sep 2010
    Wichita, KS
    I ran into to this very issue myself this weekend with my 08 XLV. Poured the the water over the fuel pump and baam, it started!!! Thank God I read this forum as we were stuck in the rain and hail storm!!!
    So, what can be done to prevent this? Elec pump, so I am thinking I caould wrap it to insulate it from soaking up the engine heat. It appears to me that there really needs to be a vent put in that comaprtment to allow the heat to escape or relate the pump away from it.
    What has others done as this must be a situation others have ran into.
    2008 Mobius XLV, Z5 Rack, RockFord Fosgate Amps and 12" Rockford sub, DBoot5 8" & 6" Tower speakers, Kicker Amp and 6.5" interior speakers, Inland Surf, Hyperlite, Liquid Force, Aerial Swing Away Racks, Perfect Pass StarGazer, ACME 1235 and Evolution Cover.
    Aug 2010
    Acworth, GA
    They only started putting the fuel pump in the gas tanks in 2010, prior to that is is somewhere on or near the engine if I recall correctly.
    Sep 2009
    Copperas Cove, TX
    Quote Originally Posted by gonracn View Post
    Skiers Choice is very aware of this problem so much that they have a "fix" for it but it'll cost you approx $500 for parts and labor for a second fuel pump. So you'll have 2 pumps. You'd think they would recall the effected year models and replace or fix with an adequate pump. Imagine how many Moomba owners (possibly Supra owners) are left stranded in adverse conditions, scared kids because they are in a broken boat, and cost of tow service to the unaware owner who could have poured water on the fuel pump. Please SC, step up and recall the boats and do the fix for free for the owners who pride themselves on their SC boats.
    Apr 2006
    Neely Henry, AL (live in Atlanta)
    Check down under your oil filter - my 06 Outback V was located there.
    2010 LSV
    2006 Outback V (sold)
