    Jun 2011
    Arkansas
    Default Right ballast keeps filling up
    I have a 04 lsv. My right side ballast keeps filling up on it own. is there a valve to replace when this happens. Any help would be nice as this is my first season with this boat.
    May 2011
    Fargo North Dakota
    Default ballast
    I just got my boat this spring also and the same thing happened to me......find your pumps for your rear bags, they each have a small black leaver on, flip it up and that will only allow the bags to fill when you use the switch.
    2005 Moomba Outback
    Jun 2011
    Arkansas
    Default ballast
    thanks, I will check it out this weekend.
    the black levers are on the grey valves on the manifold above your v drive under the rear bench seat. the fill pump feeds the manifold. theze are usually the culprit of auto fill issues
    Jun 2011
    Arkansas
    Smile ballast
    Thanks guys. I flipped 1 of the little black levers and it stopped filling by its self.
