Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
  1. #31
    Jul 2010
    Pacific Northwest
    Quote Originally Posted by squeeg333 View Post
    Well crap then! I know you asked the question before, but did you hear anything/find anything about leaving this circuit open all the time? I'm thinking of doing that in lieu of fishing a wire back to the starter.
    Did you try this? I'm also thinking of doing the same.
    2004 Moomba LSV Blue
  2. #32
    Feb 2008
    Traverse City, MI
    The SI option is virtually pointless, for the following reasons:
    -Many times when you start, the batteries aren't combined anyway, due to voltage on the 'house' battery vs. the start battery.
    -If the batteries are combined when you start, the ACR will separate House and Start almost instantly, due to the voltage drop from the starter cranking, giving you essentially the same benefit that you'd see from the SI circuit.
    -If you are running a single battery, or dual battery without the ACR, you don't have Starter Interrupt - this is how the boats come from the factory, and nobody has had any issues with it for the last 20+ years, lol.
    Long story short, save yourself the headache. I'm running my ACR without the SI hooked up.
    2013 Outback V
  3. #33
    Dec 2006
    Tigard, Oregon
    I disagree with your first two points. To your first point, when you are changing riders and shut off the engine, the ACR will stay combined since the voltage on both batteries will be above 12.75. I have a remote LED on the dash and the light stays on so I can confirm this.
    To your second point, the ACR will NOT "separate House and Start almost instantly, due to the voltage drop from the starter cranking". The voltage in one battery has to be below 12.75 volts for 2 min. or below 12.35 volts for 10 seconds for the ACR to open (this is stated in the manual). This is exactly what the SI circuit does - it causes the ACR to open instantly when the starter is engage, if the SI wire is properly hooked up.
    No comment on your third point but we hear of lots of cases where someone's stereo suddenly died. How do we know that it's not due to the sudden drop in voltage from the starter being engaged?
    Al
  4. #34
    Jul 2009
    Spokane, WA
    I did pull the fuse a while back, and things have worked well so far. I can't comment on the safety of the setup, or anything to that effect, but I know that so far, things are working well. I would like to re-connect that circuit, since I went to the trouble of routing the wire for the SI circuit. I just haven't had any time at all to mess with it (I'm still kind of hoping that Al will do some testing for me/us)!!!
    2015 Supra SC400
    08 LSV - Sold
    Go big, or go home.
  5. #35
    Dec 2006
    Tigard, Oregon
    Same here - I just disconnected the SI wire and have not gotten around to running a wire to the starter yet. Probably won't get to it until after the boating season is over.
    Al
  6. #36
    Feb 2008
    Traverse City, MI
    I usually don't shut off when picking up riders, and if I do its probably for more than 2 minutes, so I guess that would explain why that makes sense for me.
    I also have a remote LED, and every time I start the boat, the ACR seperates (light goes off), which is what I was basing that statement on
    2013 Outback V
