Results 1 to 10 of 29
Thread: Where does the ballast drain?
06-11-2011, 02:56 PM #1Junior Member
- Aug 2010
- 9
This may be a stupid question but....
I have a 2010 Moomba LSV that I traded for. My old Supra Launch had the Bertha system with drain holes for ballast on the side of the boat. When we drained the bags, water went out the side holes (like the bilge).
I filled the sacs for the first time yesterday and then drained them after we rode. They drained... the boat got lighter... I know the water was gone... BUT does it pump back out the bottom? If so, why do I have three drain ports on the side of the boat? Two on the right and one on the left....
06-11-2011, 03:11 PM #2Senior Member
- Sep 2010
- Lighthouse Point, FL
- 211
You are correct. They drain out thru the pick ups. The three holes in the side are vent / overflow
Hope this helpedREALLY????
06-11-2011, 06:54 PM #3
Where do the vents attach to the bags on the 2011 xlv i looked at.Had the air plug in the vent holes, so kinda confused
06-11-2011, 07:41 PM #4Senior Member
- Sep 2010
- 211
Typically the bags have three holes. One on the bottom and 2 on the top. The bottom one should be a 1" to fill. One of the tops is plugged and the other is a vent. On my boat all the connections are in the rear and the front vent is capped
REALLY????
06-11-2011, 09:37 PM #5
That makes sense.
06-13-2011, 08:21 AM #6
My 2009 Mobius Lsv does not drain out the side either.. I have the middle bag half full don't hear a pump running so I turned it off.. But I will see if it drains there... Meet up with a fellow member yesterday his 08 drained out of the side holes
2009 Moomba LSV..Kenwood Head unit Kicker subs and 4 wet Sound tower speakers..3 kicker amps.. Green and Black ( green like the payments black like my eye when i brought it home ) lol J/K
06-13-2011, 09:43 AM #7
I believe 2009 is when moomba went to reversible pumps. So on your boat, the water drains back out the same way it came in - thru the intake under the boat. On the pre-08's, there is a separate drain pump that drains the water out thru the side thru hulls. The side thru hulls in your system is to let the air vent out of the bags and gives the water a place to go if the bag is full and the pump is still running (since the pumps are on timers).
Al
06-13-2011, 09:47 AM #8
06-13-2011, 10:24 AM #9
No prime to empty.
The priming is from when you pull the boat out of the water the water is drained from the pump to the hull and you have to refill that section of hose, hince the primming.
Also since you have Jabsco type pumps they have a much better suction to pull the water into them with the impellors, the Areator and Tsunami pumps the 08 and older boats have the pump needs thats forced water to push the air out of the blades so it can start pumping water. Other wise is will get the Air lock people talk about.
Jabscos are much more efficent at pumping and draining then what i have but the nice things about the pumps i have is if i forget and leave them on, no big deal no damage done.
Jabscos will burn out the impellors and your stuck buying new ones.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-13-2011, 10:26 AM #102009 Moomba LSV..Kenwood Head unit Kicker subs and 4 wet Sound tower speakers..3 kicker amps.. Green and Black ( green like the payments black like my eye when i brought it home ) lol J/K
