Results 1 to 6 of 6
Thread: I killed my boat. Need help.
06-10-2011, 11:52 AM #1
I removed the battery to work in the compartment and when I connected it back, I head a big pop from the engine compartment. I connected the positive first, then the negative.
Did I blow something up?2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
06-10-2011, 12:16 PM #2
You check the master breaker on the engine?
2006 Supra 20 - Sold
2015 Supra SE450 - Sold
06-10-2011, 12:30 PM #3
I have no idea where that is.
The engine starts but the check engine light is now on.
Also the stereo has a really high pitched noise now.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
06-10-2011, 01:40 PM #4
I got an indmar mechanic to plug into my PCM and all the error codes did not make sense so they cleared the codes and now my throttle is not responsive. This system is drive-by-wire so who knows what this problem could be.
06-10-2011, 05:43 PM #5Senior Member
- Feb 2005
- Ottawa, Ontario, Canada
- 718
Bah! I was about to finally get to do some work on my boat (haven't been out this year yet). Now you have me scared to pull back the cover. Remember previous years when life was simpler and you only had to deal with damaged props?
Sorry to hear about this stressful event. Which mechanic are you using? The nearest one I know is the fairly new Mastercraft dealer in Portland on the Big Rideau Lake.
BTW, you can ride with me if needed... after I have my boat ready.2005 XLV, upgraded ballast, Comptech swivel wakeboard and hydrofoil racks, Monster cargo bimini
06-10-2011, 05:57 PM #6
The mechanic was at Hurst Marina. They have a computer to read the Indmar PCM.
We got it all figured out.
The codes that were displaying were all quite serious but they all triggered at the same time so it made no sense.
After he cleared the codes, we decided to take it out for a spin. That is when I realized there was no throttle response. We disconnected the computer from the PCM and it was the same problem. Then we reconnected the PCM dongle to the dust cap and I got my throttle back.
Went for a 2hr wakeboarding session and its all good. Even my stereo sounds good.
Weirdest problem ever!2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
