Thread: Oil Change 2010 XLV
06-09-2011, 12:13 PM #1Junior Member
- Mar 2008
- Crane Hill. AL
- 25
Oil Change 2010 XLV
I have a 2010 Moomba Mobius XLV with the standard 325HP 5.7L. My question is do I have the pump the oil out of the oil pan? I had a 03 Outback and was able to run the hose out of the bottom of the boat just drain it out. If someone could give some hints/tips I would greatly appreciate it. Also needing to change the transmission fluid, it has the ZF45C
Thanks Austin-Toys-
-2003 Moomba Outback LS(SOLD)
-2010 Moomba Mobius XLV (SOLD)
-2014 Moomba Mondo
-2006 Yamaha YZ125
06-09-2011, 12:21 PM #2
Peta Oil Extractor:
http://www.pelaproducts.com
Alternatively, you do have a hose that you can pass thru the drain hole at the back of your boat.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
06-09-2011, 02:31 PM #3
Second that - the Pela is a great tool to have. It works great, even if you've got cold oil (it'll just take longer obviously). But you can use it everywhere - including your v-drive oil change.
Done and done.2015 Supra SC400
08 LSV - Sold
Go big, or go home.
06-09-2011, 03:15 PM #4Junior Member
- Mar 2008
- Crane Hill. AL
- 25
Thanks for the responses. I ran the hose out of the back and nothing ran out. I was thinking I was going to have to use a pump.
-Toys-
-2014 Moomba Mondo
-2006 Yamaha YZ125
06-10-2011, 10:40 AM #5
