Results 1 to 10 of 15
Thread: Another ballast question
06-08-2011, 01:23 PM #1Junior Member
- Aug 2010
- 19
Question from the mechanically inept. I have gravity III ballast system and the back two bags fill and drain fine. Front bag has stopped working. Cannot hear the pump come on like with the rear bags. I tried filling it by hand in the driveway and it doesn't empty either. The red light below the ballast label turns red when depressed and stays solid for about 10-15 sec then flashes slowly. Any ideas what to do next? Thanks in advance for any help. Please speak in simple, specific terms. First wakeboat with ballast so I am learning as I go here.
2009 Mobius LSV, Wakeplate, Gravity III, Z5, Dual Batteries, Roswell Tower Speaker/lightbar combo, 12" Sub, Kenwood head unit, KAC 7204 amp, KAC X40 amp, 6 Kicker in boat coaxials, Pro Mariner Charger, Evolution cover.
06-08-2011, 01:30 PM #2
Run a search on ballast and impeller. Good luck!
06-08-2011, 02:03 PM #3Junior Member
- Aug 2010
- 19
I have searched. It seems people have manually opened the valves, I don't know where to find them. I see the lever valves on either side of the v- drive. From there they appear to route to the back of the motor. Where are the pumps located? Where are the ballast fuses located? There are numerous labeled fuses under the drivers dash but none are labeled ballast. Also, does the flashing light mean something?
Thanks2009 Mobius LSV, Wakeplate, Gravity III, Z5, Dual Batteries, Roswell Tower Speaker/lightbar combo, 12" Sub, Kenwood head unit, KAC 7204 amp, KAC X40 amp, 6 Kicker in boat coaxials, Pro Mariner Charger, Evolution cover.
06-08-2011, 02:12 PM #4
All 3 bags are filled by one pump. Its a big white pump that also has a shut-off valve connected to the thru-hull intake. If you can fill the two rear bags, there is nothing wrong with your fill pump.
The ballast fuses are located under the steeting wheel on the back wall where your feet go when driving.
Not sure what a flashing light means. I have never seen that before.2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
06-08-2011, 02:12 PM #5
Allright, sorry. I'm almost positive that you are looking at posts that concern an older version of the GIII ballast. They should have changed the name when they changed the system. Your (new, better) system should have 3 reversible pumps. The pumps will burn up impellers now and then. The old system used aerator pumps-- just a single pump to fill (Rule 2000) and three smaller Rule pumps, 1 near each bag to empty. It sounds as though you have one pump that is overheating, may have tripped a breaker or may need an impeller replaced. Others with more knowledge about this particular system should chime in soon.
06-08-2011, 03:26 PM #6Junior Member
- Aug 2010
- 19
Thanks Kane. I found the pumps. Located behind carpeted endwall in back left locker. Three pumps and three black boxes I assume contain the fuses. Problem, I don't know how you open the boxes. If the impeller is burned up in the pump, I believe that's a job for the dealer. Would like to try the fuse first though. Anybody with similar system?
06-08-2011, 03:35 PM #7
Don't run to the dealer just yet. You can actually get a better impeller if I remember correctly from earlier posts.
06-08-2011, 03:42 PM #8
think he will want the "green" for the upgrade.
Ed, where are you?Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
06-08-2011, 03:48 PM #9
Try some of this and maybe give Wakemakers a call for advice. They know your boat and will walk you through it.
https://forum.moomba.com/showthread....green+impellerMy Mom said I'm not allowed to get wet!
06-08-2011, 08:38 PM #10
There is breaker in the battery compartment for the ballast marked as such on right side wall probably. If your other pumps are working you have to determine if this pump is actually getting power to it or if the motor is burned out. The black boxes are the timers no fuse there. Green impellers are thebest and easy to change. Get yourself a cheap digital multimeter fo checking current to the motors/pumps could be a loose connection , maybe a stuck / frozen impeller impeller. 3 slot screws to remove the impeller cover although I think the forward one is the middle pump which faces down and has to be removed to get at the screws.
09 21v LAUNCH
99 Outback LS. Sold
Doug
