Thread: Grab Rail as Tow Point?
06-08-2011, 08:34 AM #1Member
- Sep 2010
- Camp on pool 8 of Allegheny River (Adrian, PA)
- 64
Hello - Just wanted to understand if the grab rail located on the transom of the Outback's can be used as a tow point?
I have been using the ski pole and the tower to tow with and wanted to understand if there is enough strength in the grab rail to use as a tow point also. The 2003 model has four anchor points where the grab rail mounts onto the transom above the swim platform.
My thought is to use it as a point to tow a tube or skier if the number of people in the boat requires someone to sit in the rear seat.
Thoughts?...Best Practice?...
Thanks2003 Outback
Boat name = Lynn Syndrome
Its a condition that runs in the family...Judy Lynn (mother-in-law) Heather Lynn (wife) & Megan Lynn (daughter)...no known cure...but the boat helps
New boat for me on 10/9/10.
06-08-2011, 08:43 AM #2
Yes the O ring in the middle is designed to be a tow point.
The outter rings that you use to tie the boat ot the trailer, Transom tie downs can also be used as a tow point but then its much harder for the person to stay behind the boat.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-08-2011, 10:19 AM #3
My 02 does not have the ring in the center of it. It is just a straight handle. I definitely would not even consider it. I think with the newer boats they must have reinforced that area.
-Mark
"Hey you only live once"
06-08-2011, 11:50 AM #4
Yea if theres no ring then dont pull with it. Its just a grab handle, mine has the ring in the middle but i prefer to use the pylon
[COLOR="#696969"]
