Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
    Default Prop Test Results Part 2
    Last spring, I tested three props - the stock OJ prop, the OJ wakeboard prop, and the Acme 537 which falls in between the stock and the wakeboard prop. Below is a link to that post and the dialogue that ensued.
    https://forum.moomba.com/showthread....p+test+results
    After that test, I went with the Acme 537 and used that prop all summer. It met all my performance requirements until one day late in the summer. That day, I had all my ballast full (1300#'s), had 6-7 adults on board, and was trying to pull up a wakeboarder. We got him up, but it took a while. That was when I found the limits of the 537 and since that day, I've been thinking about a new prop.
    I didn't want the OJ wakeboard prop because in my tests, it lost 4 mph on the top end and because it growls at low speeds as many people have commented. It also turns more rpms at all speeds resulting in poor fuel efficiency all the time. The 1235 is out because it's overkill and there is supposedly a trailer clearance issue witht he LSV. The 1433 is the next choice but I would have the same issue with this prop as with the OJ wakeboard prop - too many rpms and higher fuel consumption all the time. Which brings me to the little known 1847, which is the same diameter (14") and pitch (14.25") as the 1433 but has more cup (0.150" vs 0.105"). According to Jim at Acme, the additional cup has the effect of almost an inch of additional pitch on the top end with negligible loss of holeshot on the bottom end. And it turns fewer rpms than the 1433 at the same speed. Sounds good to me and wakemakers (who also sells props but the way) is just down the road from me and they happend to have one in stock, and Spencer said I could try it out and if didn't like it, could bring it back for a full refund. So I picked it up Friday and tested it today.
    Below is the updated prop results form with the 1847's performance data added. The testing conditions were almost identical as last spring so the comparisons are valid. Only difference is that last year, my 14 year old son was with me (he weighed about 100 lbs) whereas this year, it was just me in the boat. The numbers speak for themselves. I didn't bother testing it with ballast as I know it will have more pull than I will ever need. Needless to say, I am keeping this prop and will be posting my Acme 537 and my stock OJ in the classifieds soon.
    Here is a shot of the gauges during my top speed run. This shot highlights the importance of using a gps when quoting top speed. I calibrated both the analog speedometer and the perfect pass digital speedometer to the gps at 23 mph, yet at 39 mph (as indicated by the gps), the analog speedo reads almost 41 and the perfect pass display reads 38. The second pic shows a crop of the gps where you can see 39 mph in the upper right corner of the display.
    The two Acme props. The 1847 is on the left and the 537 is on the right.
    Aug 2006
    Salt Lake City
    Interesting. I am about to the point of being tired of vibrations in my oj 14.25x14.
    Was leaning toward 1235 but like these numbers....
    Brad
    2006 Moomba Mobius LSV sold
    2004 Outback sold
    I was really looking at that 1847 but no one had done a test on it until now! Thank you for doing this as this confirms my choice for my next prop. The OJ growl is VERY annoying and to me it makes my boat feel very very cheap.
    Looks like a perfect choice. Your numbers sold me on the idea of the 537 (I know, I know, I actually got the 1161, which is the .135 cup instead of .105 cup in the same size prop - 13.5 X 16 ). It has been perfect. Now I know what I will need to go to when my 11 year old boys start demanding more ballast in a few years.
    And here I was all convinced that the 537 would be my next prop...
    I'm liking that 0-23mph in over a second faster though!
    Fort Saskatchewan, Alberta
    Now we just need a group buy deal!!!
    2006 Mobius LSV 325 hp MPI Indmar
    Aug 2006
    Salt Lake City
    Didn't tow any riders, but I was very pleased with the results of putting the prop on!
    Brad
    2004 Outback sold
    Found the ole fashion prop puller...
