Results 1 to 7 of 7
    Jun 2009
    Minnesota
    Default Runs great, Radio, bilge and blower not working
    I have a mystery that I could use somm help with. I took my 04 Mobius LSV out yesterday and everything worked fine. 10 minutes in to the day the radio stopped working, 5 minutes later it started working, and then another 5 minutes later it stopped completely. Soon after the bilge and the blower also stopped working. Engine is starting just fine. Had the battery tested and it it is fine also. I tightened up the connections to the battery. I looked under the dash and near as I could tell everything was tight. Admit I was a little overwhelmed by the number of wires down there. I also noticed that now none of the controls are lighting up either.
    Anyone have some specific places to look?
    Arkansas
    Sounds like a breaker issue? I'm not familiar with the setup on that boat/year model.
    Someone else should chime in and will know more.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    should be a breaker in the battery compartment behind the spotters seat.
    should be on the wall facing the stearn.
    thats where it is on my 07 OBV
    Jun 2009
    Victoria BC Canada
    I would take a look under your dash to see if you have any loose connections. Sometimes those electrical clips fall of the terminals.
    2007 Outback V
    Jun 2009
    Minnesota
    Found the breaker and reset, and found the loose wire for the stereo.
    all better, thanks
    Feb 2008
    Traverse City, MI
    Glad you found the issue!
    For future reference, there should also be a fuse box under the dash - I had the bilge pump short out and pop the fuse, which caused all of the dash switched electronics to work. The fuses are re-setable (does that make them breakers too?)
    2013 Outback V
    I was about to say there circut breakers LOL.
    I thought mine were fuses untill last week when my IBS wouldnt drain, i pulled all the covers and found circut breakers, no fuses.
    [COLOR="#696969"]
