Results 1 to 10 of 12
06-06-2011, 09:16 AM #1Junior Member
- Sep 2010
- 5
Need help with '99 Moomba Outback Please
Hey Guys,
I've got a '99 Moomba Outback with an Indmar 5.7, 310hp w/ Holly Carb.
Yesterday was the first time we've run the boat this season. It left us stranded within' 5 minutes on the other side of the lake.
We were running across the lake at about 70% power and then the engine just slowed and died out.
We fogged the intake with starting fluid and it started right up and again died. I figured we may have water in the gas. We siphoned the bottom of the tank, filled it back up, and added some dry gas. No luck. Then we noticed the fuel pump was not running.
Here's the big question:
When should the fuel pump turn on? What turns it on? Is there a relay or a fuse? We can get the fuel pump to run by connecting 12v to it but it doesn't run on it's own with the key "ON" or while cranking. We dumped the water separator and can't seem to get any fuel into the engine now.
Any ideas??
06-06-2011, 10:04 AM #2
Do you have power to everything else? There's a master reset button on the back side of the engine pretty high up that is very hard to see unless you put your head behind the driver's seat and look in there. Try pushing it and see what happens.
06-06-2011, 10:25 AM #3Junior Member
- Sep 2010
- 5
Thanks for the quick reply!
I do have power to everything else. (gauges, radio, starter, horn etc)
There is a red, what looks to be a master reset, on the back of the engine, where the main wiring harness plugs into a plastic cover. Inside the cover is the starter solenoid and some other wiring. That particular breaker seems to be good. Could that be the one you're referring to?
06-06-2011, 11:40 AM #4
Big, red button. That's the one. On my 2000 OB some stuff would work but some stuff wouldn't after I blew that breaker trying to run 3 ballast pumps off the 12v outlets. Boat would not run though. One push and I was good to go.
06-06-2011, 11:48 AM #5Junior Member
- Sep 2010
- 5
Yea, checked that one.
As far as the fuel pump goes, is it supposed to run any time the key is in the "ON" position? Or, any time the engine is running?
I can only get it to run by hooking 12v up to it.
06-06-2011, 01:35 PM #6Banned
- Oct 2005
- Durham, NC
- 649
It sounds like the lead for the fuel pump has come off the ignition switch. My Outback has done this in the past.
06-06-2011, 02:08 PM #7Junior Member
- Sep 2010
- 5
06-06-2011, 02:11 PM #8
Here are a few statements that I stole from older posts by "Engine Nut":
There is a fuse in the system that protects the pump.Have you checkedit.Itis in a fuse block with two other fuses and is located near the plug on the engine where the boat harness and engine harness plug together. It has a cover in ot that is a couple of inches wide and 1/4" or so thick. The fuses are under that cover.
The fuel pump on a carb engine does not come on with the ignition. It works only when the engine is either cranking or running. It gets its power during cranking from the starter solenoid and when running from the oil pressure activated fuel pump safety switch that is located next to the distributor. I have attached a diagram. Some of the older switches have three terminals instead of two but they still work in a very similar manner.15 Mondo Surf Edition
02 LSV - Traded In
06-06-2011, 02:20 PM #9
The oil pressure activated fuel pump safety switch has been the root cause is several cases such as yours.
Kraig - 2010 Outback V
06-06-2011, 02:48 PM #10Junior Member
- Sep 2010
- 5
Thanks Guys,
I'm starting to see that safety switch in several threads now. I think I'll just replace it for now, it's only $16.00, and start there. I'll also check for any loose or disconnected wiring at the ignition switch. I haven't seen any fuses anywhere, but I'll look again. Thanks for all the ideas that have been submitted so far.
