Results 1 to 10 of 10
Thread: Carpet Cleaning
    Nov 2009
    Nebraska
    Default Carpet Cleaning
    Whats the best way to clean the carpet in the moomba? Is resolve ok to use on it.
    Ottawa, Ontario
    I hear soap and water is all you need.
    I personally use a Bissell green machine
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
    Aug 2009
    Montana
    Powerwash them. That'll work the best!
    2015 "NOT A MOOMBA"
    Why Not? Play Hard! Get wet
    Sep 2009
    Austin, TX
    Little Green Machine from Bissel. Cost about 75 bucks and I clean the carpet about 4-6 times a year. Can steam it in about 20 minutes and does a great job.
    Skylar18
    2007 Sunsport 22V
    Arkansas
    Another little green user.
    It's not only a boat tool either. Works great in the house as well.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Sep 2009
    I was just going to look around for some similar suggestions, since we have a new baby doing her thing staining up the carpet, and I wanted to use that as an excuse to get something to do the boat carpet too. I'll give the little green a shot, thanks guys.
    I think I saw in another thread there was some hesitation about using a steam cleaner due to the rubber backing on the carpet? Have you guys seen any issues? I'd guess not if you are recommending it.
    Sep 2009
    Nevermind looks like it's not a steamer, just took that from the post above.
    Sep 2009
    Austin, TX
    I've had no issues at all with it and I too use it around the house as well. Does a great job on couches.
    Skylar18
    2007 Sunsport 22V
    Doesn't that blow crud, sand, crumbs, whatever all over everything else in the boat?? I've read a few different people on the forums doing it, I'm just not that anxious to spend twice as long afterwards dealing with the collateral damage and mess from it.
    My mind not only wanders, it sometimes leaves completely.
    2001 MobiusV - Loaded with Ballast, Exile, Blood, Sweat & Beers
    Dec 2006
    Tuscaloosa, Alabama
    I agree. The little green machine works real good. Tornado got mine so I got to get another one soon. Also use Folex (I think) from Home Depot. Excellent spot remover
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
