Results 1 to 10 of 19
Thread: ballast pump woes...
06-04-2011, 05:27 PM #1
So took the Outback to a public lake yesterday and had ballast issues. Pump would turn on, but would not pump into the ballast bag. removed fitting from ballast bag, no water at all going through hose. removed water strainer, and water was flowing with pump off. With pump on, water flowed faster. Put back on, and tight, but no water to bag. Must have a kink, or? Any ideas to check? Also, any way to check a ballast system on the trailer?
08 Outback. Private Lake Owner.
06-04-2011, 05:31 PM #2
check your sprinkler valves and make sure they are actuating. i have heard stories about them getting stuck.
06-04-2011, 05:56 PM #3
06-04-2011, 07:53 PM #4
yeah. put the boat on plane. My ballast intake is just a hole, no scoop.
How do I check my sprinkler valves, and what use is the valve anyway? is it just a check valve? the pump pumps the water, why do I even need the valve? Can i just replace with a 1 way check valve?08 Outback. Private Lake Owner.
06-04-2011, 08:20 PM #5
You have the Gravity 1, right? Not sure why your intake doesn't have a scoop since that's how the pump is primed. The reason for the sprinkler valve (at least on an intake with a scoop) is to prevent the bag from filling when on plane. Without the valve, water would be pushed thru the pump and into the bag even if the pump is off. It also prevents water from draining out when you don't want it to.
Al
06-04-2011, 09:06 PM #6
Yeah, Gravity 1. I did have to go out and look, I do have a scoop! I wonder why my system isnt working? Okay, so I need the sprinkler valve... wonder what else I can check...
06-05-2011, 07:08 AM #7
did you winterize and pull the water stainer off and put it on backwards? it only flows one way or is it clogged with stuff.
06-05-2011, 09:18 AM #8
no winterization was done, and it was working a month ago. I pulled it out of the lake (damn drought, water getting low) and it sat on my trailer for a month. I'll have to see, but I'm pretty sure I'm getting water to the straner, and it flows faster when I turn the pump on, meaning things are good at least up to the strainer.
06-05-2011, 11:11 AM #9
If you have a fake a lake, you should be able to test it on the trailer. Just attach it to the ballast intake. I would start by removing the hose quick connect from the valve, turning the ballast pump on, and see if water flows thru the solenoid. If not, unscrew the valve from the manifold and see if water flows. So do this until you isolate where your problem is - the valve, strainer, pump, or hose.
Al
06-07-2011, 01:21 AM #10Junior Member
- Jun 2010
- NW Arkansas
- 3
Had the same issue with my 2010 LSV this weekend! Ended up running it 2 or 3 times on plane then it finally caught prime and started. The last time I went slowly to plane thinking it might push more water into the scoop with the nose up a bit longer and it worked! Had no idea you have to prime pumps till I saw it on the board (first wakeboard boat)!
