Results 21 to 30 of 45
    Oct 2008
    N.E. Minneapolis
    Not sure about the access in Moombas, I know in some brands the plate is drilled and taped so installation is pretty easy (aside from removing any 5200 if it was used) as you just need to use different hardware to accommodate for the new brackets being a bit different thickness.
    Can you fold the platform with those brackets if you have a wakeplate?
    Apr 2008
    California
    Nope i already looked into these many months ago just to be able to get around the boat! Wakeplate is in the way and will only allow limited fold down, even then the weight of the platform is on the plate. No go for me.
  4. #24
    Speaking of all this platform brackets, Claudia has pretty much said in no uncertain terms the first upgrade this year has to be a FAE because she and another close friend were getting headachs when surfing. I know this system bolts to the platform brackets.
    Anyone have this seen it help or hurt the platform and brackets?
    I know with this set up i cant just pop the swim deck off anymore so i figure once the boat comes out of winter sleep it will stay bolted up till fall.
  5. #25
    Maybe try a slightly more expensive wine cooler.
    Tooele UT....
    mmandley, this would be my recommendation. much cheaper than an fae, and they come in fashionable colors to match their swimsuits
  7. #27
    You get the coolest tan lines from that thing too.
    Apr 2008
    California
    Actually you can pop off the platform. They offer some sort of quick release brackets/mounts from i saw last year on WW. I've never seen issues with the brackets or platform using these.
  9. #29
    Kane wish she drank it would make dealng with a lot of other issues easier lol
    Sandm yea I see plenty of peeps on the water who should use your idea to save us others from Kanes idea above lol
    Razz thanks I'll look into that
  10. #30
    Aug 2009
    Montana
    Quote Originally Posted by snowboardcorey View Post
    If the wedges don't do the job I'd recommend swapping the brackets over to the OJ Folding ones, they are a much sturdier construction (not cast) and allow you to simply fold the platform instead of lift it off and store it somewhere else. FWIW they are available for Moomba and Supra.
    http://www.ojprops.com/products/fold...atform_bracket
    This topic has come up in the past. But I have yet to hear from anyone that has the OJ folding brackets? I'd be interested in a member review who has some experience with them??? Anyone?
    2015 "NOT A MOOMBA"
