Results 1 to 10 of 25
05-24-2011, 01:35 PM #1
Where can I find one of these? *pic*
I need to drill a hole to pass an ipod cable and want to achieve a nice clean look.
Any ideas?
2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
05-24-2011, 01:45 PM #2
I want one of these too...
05-24-2011, 02:22 PM #3
if you cant find one of those you can always use one of these:
05-24-2011, 02:33 PM #4
How about removing the 12V plug, use a dremel or tool of your choice to make a small notch in the bottom of the hole just big enough to accommodate the ipod cable, insert the cable then reinstall the 12V plug.
AlAl
05-24-2011, 02:41 PM #5
05-24-2011, 02:45 PM #6
Another option, drill a hole straight through, and use a rubber grommet size to fit snugly in the hole with a hole through the middle large enough for the cable to pass through.
Like this:
05-24-2011, 02:46 PM #7
Like Dusty's option the best.
05-24-2011, 02:47 PM #8
05-24-2011, 02:49 PM #9
Yup, my solution is completely dependent on which cord he uses.
05-24-2011, 02:51 PM #10
