Results 1 to 10 of 13
Thread: vdrive oil leak?
05-23-2011, 10:05 PM #1
vdrive oil leak?
Anyone had issues with their vdrive leaking a little oil? The bottom side of my vdrive is always wet with oil. Only a few drips into the bilge per season, so nothing major, but I'm wondering where it could even be coming from. I tried to snug up all the bolts and plugs but none were loose. Any ideas?
05-23-2011, 10:26 PM #2Senior Member
- Jun 2007
- 883
yeah, I've noticed it a bit as well.. i usually can notice the oil when i have water in the boat, easy to see then. i always check the dipstick, never seems to get low though.
2006 Moomba Mobius LSV
Stereo: Kenwood KMR-D562BT
Ballast: 750 Surfside locker, 400 Surfside mid boat, 400 Gravity I, 400 Bow
Surfboards: Inland Surfer Red Woody, Triple X Composite X 58"[/SIZE]
05-23-2011, 10:31 PM #3
Mine was leaking from the output shaft seal maybe elsewhere on the back side. Also from the pressure sensor. Had to put a paper towel on the floor to determine where it was coming from. But I had to add oil to my unit so I know it was leaking.
09 21v LAUNCH
99 Outback LS. Sold
Doug
05-23-2011, 10:35 PM #4
05-23-2011, 10:39 PM #5
they replaced the vdrive under warranty
09 21v LAUNCH
99 Outback LS. Sold
Doug
05-23-2011, 10:39 PM #6Senior Member
- Apr 2010
- saskatchewan, canada
- 334
mine was a leaky fitting on the pressure sensor, just teflon taped it and tighened it up and good to go.
05-23-2011, 10:57 PM #7
Just checked the sensor and that seemed to be fine... bummer, that would have been too easy.
05-23-2011, 11:11 PM #8
Mine leaks at the bottom plug a little. used teflon tape last time but it still does it.
05-23-2011, 11:16 PM #9
05-24-2011, 11:41 AM #10
