Results 1 to 10 of 16
Thread: impeller housing bolt broken
05-22-2011, 09:03 AM #1Member
- Jul 2010
- Deep River Ont
- 83
ok I'm an idiot and broke a brass impeller bolt by overtightening, anyone ever try to get one out after it broke off?? help please!!
05-22-2011, 09:58 AM #2
It wont be easy due to its placement. You will need a very small drill bit and easy out.
If your lucky you might be able to get a metal pick almost like the dentist uses and turn it. With broken bolts once the head is off there is no tension on the threads so it should turn fairly easy.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-22-2011, 03:25 PM #3Junior Member
- Apr 2009
- Okanagan
- 19
I've fixed a couple of these and both times I was able to turn it out by hand. Finding a new screw is the real challenge.
05-24-2011, 12:19 PM #4Member
- Jun 2008
- Bellevue, Wa.
- 31
I have done this twice. I had to remove the pump from the engine. That was the hard part because it was hard to reach. The broken off part of the bolt came right out. One time I could spin it with the friction of my finger and the other time it was deeper so I just stuck a little screw driver down on it and pushed down as I turned, it came right out. I went to where I get my parts and they sold the brass bolts separately but they went out to the shop and found an engine that was going back for warranty and gave me the bolts out of that one for free. I know you can buy them on line from Bake's Marine, look under Johnson Pumps.
05-24-2011, 01:45 PM #5Member
- Jul 2010
- Deep River Ont
- 83
is it necessary to use brass bolts??
05-24-2011, 02:58 PM #6
This came up once before a year or two ago. I can't remember if the guy could only find stainless or what. Maybe try running a search on impeller and screws or bolts and brass.
05-24-2011, 03:05 PM #7
05-24-2011, 03:31 PM #8
Item: 685005
Description: COVER SCREW - JOHNSON PUMP
Johnson raw water pump cover plate screw. For all Indmar applications w/Johnson pump
http://www.inboardonline.com/
05-25-2011, 07:47 AM #9Member
- Jul 2010
- Deep River Ont
- 83
Thanks All, found everything I will need at Bakesmarine online, the screws were $2.30 for 4 ( ordered 8 ) Gaskets $4.00 each and the impeller ( ordered one just for an extra ) at $29.00. I bought an impeller from a local marine dealer the other day and they charged me $70.00 ....rip off!!!!
This is a GREAT site........thanks
05-25-2011, 11:17 AM #10
always good to have a spare impeller in the boat
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
