Results 11 to 13 of 13
Thread: Battery Setup
    Henderson, NV
    I'm pretty sure that every new boat of every brand comes from the factory with a lead acid battery. Just sayin'.
    cab- fify...
    Aug 2021
    Your steps are correct, although, you can save a step by not removing the chrome. If you scuff all the chrome good enough, you won't have any adhesion problems. You also don't have to wet sand, Oferta silnikowa: PB silniki benzynowe, ON silniki diesla.https://autowikius.com/. W nawiasie kod silnika, czyli np. PB 2.0 (LF) oznacza silnik benzynowy o pojemności 2.0 i kodzie fabrycznym LF.,you can dry sand it just fine. You don't have to sand in between coats unless there are defects or something gets in the paint.
    Jul 2021
    I'm pretty sure that every new wakeboat of every brand comes from the factory with a lead acid battery. Just sayin'.
    Boats don't come with batteries from the factory. 😉
