Results 21 to 30 of 34
Thread: Amp for HLCD'S
  1. #21
    Des Moines, IA
    Quote Originally Posted by DOCDRS View Post
    so which kicker amps would fall into the class d category?
    Their IX line
    http://www.kicker.com/ix_amplifiers
  2. #22
    Oct 2010
    Lake Wylie NC Area
    The IX line I mentioned on page one. The IX500.2 is good power the 4 or 6 pod KM6500.2 setup. The IX500.4 is awesome power for the 4 pod setup and a pair of IX500.4's for the "6-Pack".
  3. #23
    Ottawa, Ontario
    2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
  4. #24
    Des Moines, IA
    Quote Originally Posted by deafgoose View Post
    I think the ZX mono amps are class D, and I know the sub channel are on their 5 channels are as well. Pretty sure the stereo and multi-channel amps are class A/B though.
  5. #25
    Oct 2010
    Lake Wylie NC Area
    Correct. Most of the zx mono's are Class-D, but not all and none of the stereo/multi-chnl full-range zx amps are Class-D. The Zx/ZXM 700.5 is a 5 chnl Hybrid Class AB full-range and Class-D.
  6. #26
    Jul 2002
    London Ontario Canada
    thanks for all the info, i'm learning, so a kicker ix500.4 would do me?
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
  7. #27
    Jul 2010
    Pacific Northwest
    DO IT!
    2004 Moomba LSV Blue
  8. #28
    Nov 2009
    Stillwater, Oklahoma
    Hey guys!
    Mike at MLA has shared pretty much the two hot ticket setups usign current amps. Let me reiterate:
    For a single set of KM6500.2 components, (2 mids, 2 horns) witha power handling of 200 watts RMS your options are:
    single ZXM450.2 (class A/B) 150 watts per side
    single IX500.2 (full range Class D) 150 watts per side
    single IX500.4 (full range Class D) bridged to 250 per side
    For the 6-pack, which consists of a KM6500.2 set AND a KM6500 set (4 mids 2 horns) I strongly recommend the following:
    pair of IX500.4 each one bridged to give 1000 watts of tower power
    pair of ZX300.1 (class A/B) with a KX2 crossover for hi-pass filtering
    Or if you want to kick it old school, one of the old 850.2 stereo amplifiers will drive either setup quite well. Just know if you find an old 850.2 is will probably be used or a refurb.
    Hope that helps
    Phil Kicker
  9. #29
    Nov 2009
    That is what I am running on my set of KM6500.2...
    GO for it
    Phil
    Kicker
  10. #30
    Jul 2002
    hey phil , how hard is it to swap these into a 09 roswell speaker light bar as in the above pic. I've heard there is no lip or something just the back can center screw. Boat is far away so can't just go out and look at it.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
