Results 1 to 10 of 32
Thread: Fuel tank bilge pump
05-14-2011, 02:04 PM #1
I have my floor out and have water in that center hole. any pros cons in putting a bilge pump in that center.
thanks in advanceA Day at the Lake...Priceless
05-14-2011, 02:31 PM #2Senior Member
- Apr 2006
- Neely Henry, AL (live in Atlanta)
- 161
My 2010 has a drain plug at that low spot mid-gastank-ish area.
2010 LSV
2006 Outback V (sold)
05-14-2011, 08:40 PM #3
Thanks, but that doesn't really help me does it.
05-14-2011, 08:47 PM #4
A lot of other maufactures have a second auto bilge in that spot.
Probably not a bad idea! Let me know what you decide. I may do the same.
PWI as usual...
05-15-2011, 06:48 AM #5
I have concluded this water should drain with proper tilting to the stern drain plug or to the bilge pump..
Newty there is a bracket in of those hles that the fuel tank sits on, so a normal bilge won't get all the water. i used a hose will a drill pump to remove the water why i continue my mods.. just bugged me, plus it smelled musty.A Day at the Lake...Priceless
05-15-2011, 08:16 AM #6
I was thinking if i ever pull the floor out i am going to run a line down there, then Y it into one of the rear Sac drain pumps with a on and off lever. So i can switch the suction on the punp to that line. Then at the end of the day i can switch the rear pump to the center area and drain that hole before i go home.
I think it will work pretty well. I am just not going to pull my floors out just to do that mod.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-15-2011, 12:31 PM #7Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
05-16-2011, 01:00 AM #8
Joe,
I have thought about doing the same thing but I have no found and bilge pumps that discharge straight up - they all discharge horizontally and I don't think there is enough room to put in an elbow. I have not looked into it that much though.
And at least on my boat, that water does not drain out to the back no matter how steep a hill I drive up.Al
05-16-2011, 01:10 AM #9
I know its not that hard to remove the floor just don't want to unless I really need to lol
[COLOR="#696969"]
05-16-2011, 09:45 AM #10My Mom said I'm not allowed to get wet!
