Results 1 to 3 of 3
Thread: Cracked block
    Feb 2005
    Default Cracked block
    I have a 2000 mobius v drive with a cracked block. How much does it typically cost to fix??
    Oct 2004
    Marietta, GA
    Default Replying to Topic 'Cracked block'
    hey go to a savage yard and buy a used block. You can save quite a bit of money. I did not properly winterize my 302 and had to replace the manifold and the both heads. So the savage yard is a place to try next after you fall out of your shoes when your told how much the block is going to cost. good luck!!
    2005 Moomba 23 XLV
    340 HP, Clarion 5 HU, 2 Clarion wired digital remotes, 2 Wetsounds 485's, 6 Wetsounds XS 650's, 1 JL 12w6 Sub, 1 Wetsound WS420, 2 JL 300/2amps, 1 Wetsounds Sync 4 amp, 1 JL 500/1 amp. Teak swim platform, Perfect pass. Flip up Bow Light, Chrome tower Nav Light, Chrome thru hulls, Black Bimini, 2 750 Flyhigh bags, 1100 center Flyhigh bag, Acme 1235 14.25 x 14.5 prop, Dual battery system. Evolution Cover. Chrome Blower Vent Covers.
    May 2003
    south east michigan
    tk42,depending on where the crack is ,and if it cracked internelly,they can be patched with JBWELD.Some people don't believe in it,but I have done it and it has held for years if done right.
    jy
  1. cracked block
    By LSV04 in forum Service & Repair
    Last Post: 04-30-2007, 04:19 PM
  2. Fuse block
    By dburroug in forum Service & Repair
    Last Post: 06-02-2003, 05:24 PM
