Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
    May 2017
    Default Bag fill/drain hose
    Do you have your fill/drain hose towards the front or rear on your bags? Updated the pumps to reversible and plumbed the hoses to the front, thinking the rear would be better.
    New to boating and surfing
    I have the Fill / drain to the back, the pump has no problem pushing water in, having the inlet in the rear allows the bag to drain better as it gets lower. If the pumps loose prime during draining the bag wont drain all the way.
    I have the Vent on the top opposite the fill side because as the bags fill that corner is highest in relation to how the boat sits.
    [COLOR="#696969"]
    Jun 2018
    Pewaukee, WI
    Having a hard time getting the back ballast bags to drain all the way. It isn't a timing issue. I thought I read on a previous post (can't find), that people added something to the pump or line to help drain the bags. Suggestions?
    Aug 2017
    Quote Originally Posted by chwags69 View Post
    I put ball valves in the vent line, open when filling til they spill out the port, then close them. Keeps them from continuing to siphon out the vent, and when draining they drain completely with no air at all in the bag.
    2019 Supra SL450
    Jun 2018
    Pewaukee, WI
    Thanks Shoebox! Do you recall where you got them?
    A quality marine check valve in the vent line will aid on a more complete drain. Totally passive, no opening locker to do anything for fill or drain.
    Salt Lake City, Utah
    check valves work great.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Aug 2017
    I have check valves from Wakemakers. They work very marginally. And they don't stop the bag continuing to siphon water over the side.
    I open the locker to verify the bags are full anyway. Easy to turn a valve when they are.
    2019 Supra SL450
    Aug 2017
    Home Depot
    https://www.homedepot.com/p/LEGEND-V...-601/203581023
    https://www.homedepot.com/p/1-in-Blu...TMA1/300823617
    2019 Supra SL450
    Quote Originally Posted by Shoebox View Post
    Sorry to hear, my customers do not experience this with our check valves.
