Results 1 to 7 of 7
    May 2011
    Default No Power to Fuel Pumps
    I have a 2002 Moomba Outback. I have power to the gauges and the key switch but the fuel pumps will not come on. I read where the problem may be the oil pressure switch but mine is only a single wire. I have been tracing wires and checking everything I can with a meter but still no luck... Please Help
    Oct 2010
    I have the same issue with a 2001 Outback. I assume your's will turn over but not catch.
    I was told, the single wire goes to the oil pressure gauge and then back to the fuel pump. If is registers zero pressure, then it will not start. I am replacing the oil sending unit then hopefully will be back in business.
    However, I am far from the expert opinion.
    May 2011
    Mine turns over and everything but no fuel pump will come on. Thank You I will try to replace the oil pressure switch.
    Mar 2003
    Springfield Missouri
    I would first try putting 12 volts across the terminals and see if the pump runs.
    1998 Mobius
    310 HP PCM
    SOLD
    May 2011
    After some extensive wire tracing and testing I figured out the problem. It was the bottom relay switch which runs the fuel pumps. It had voltage coming in (pink wire) but was not going out (gray wire). I put a jumper across the two and the fuel pumps came right on.
    May 2007
    Richmond, VA
    Quote Originally Posted by joker246 View Post
    What's the permanent fix? Replace the fuel pump or rely on the jumper?
    2007 Outback - SOLD June 2016
    2012 RAM Crew Cab
    2015 Subaru Forester
    Stuart
    Replace the relay?
