Results 1 to 10 of 16
Thread: What's This
05-02-2011, 01:56 PM #1
What's This
Hi gang ..just putting the finishing touches on the motor and i am left with 2 unknown wires first the 6 prong (correct me if i'm wrong but i think it's to plug in a scanner) the second is the light blue wire about 6 inches long that seem to fit perfectly on the fuel pump. Does anyone know if they have 2 wires on one side of the fuel pump terminal ?? any help would be greatly appreciated.
06 XLV
05-02-2011, 01:58 PM #2
Sorry forgot the pics !!
06 XLV
05-02-2011, 02:09 PM #3
Unless someone else answers, I can look when I get home.
I wondered if we would hear from you. Thats a pretty big project. Hows it coming?Last edited by newty; 05-02-2011 at 02:13 PM.
PWI as usual...
05-02-2011, 02:37 PM #4
Thanks newty that's very kind of you.
06 XLV
05-02-2011, 10:43 PM #5
After looking I pretty sure that wire should have a little rubber boot on the end and be terminated on some sort of sensor or sending unit that is mounted on top of what would be the the casting where the oil filter would typically would plug in. I'm guessing oil pressure sending unit? The wire looks like it would reach both the fuel pump and the ending unit. Its the only wire of its type/color/size in that area sticking out of the loom.
Make sense?
PWI as usual...
05-02-2011, 11:02 PM #6
In fact I think you can see the sending unit here! I think...
Hey if you need any other location info let me know. I'd be glad to help.Last edited by newty; 05-02-2011 at 11:04 PM.
PWI as usual...
05-03-2011, 06:56 AM #7
Thanks newty I will check it out today.
06 XLV
05-03-2011, 08:04 AM #8
you were right on the money Newty, the oil sending unit still had the little rubber boot on it....Thanks a million. Also did you find that 6 prong plug on yours ??
06 XLV
05-03-2011, 08:06 AM #9
Forgot the pics again !!
06 XLV
05-03-2011, 11:06 AM #10
Sorry I was so focused on the blue wire I forgot to look for the plug. I'll look tonight. Where does the loom on that 6pin plug originate?
PWI as usual...
