Results 1 to 6 of 6
05-02-2011, 11:00 AM #1Junior Member
- May 2011
- 5
Replacing steering cable on 03 LSV?
Does anyone have any good suggestions on replacing the steering cable on a 2003 LSV? Searched some of the exsiting posts, but the links with the pic's do not work?
05-02-2011, 11:35 AM #2
did that on my 03. remove the floor-tricky part is there are 3 screws going into the floor from under the rear seats-when you have them all out the floor lifts up easily. unbolt the cable from the rudder and then undue from steering wheel, pull cable out from under dash-good idea to tie a small rope to the end to help fish it back thru the hole and under the floor where you can see. then attache everthing back the way it was.-this is the simple explanation
Hey, Its Moomba time
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
05-02-2011, 11:41 AM #3Junior Member
- May 2011
- 5
Thanks!
Any advise on getting to the rudder connection?
05-03-2011, 07:14 AM #4
drop the side panel down/ or remove-cant remember and its easy to reach-maybe one of the easier steps
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
05-07-2011, 11:01 PM #5Member
- Apr 2006
- Live in Little Rock, Ar
- 48
LSV Steering Cable
Did you find the part number for the LSV Steering Cable Replacement? I've unhooked mine from Rudder (pain to reach but easy) and have loosened the 4 bolts that hold the cable shaft tight in back
If not, I'll call Reflex cables on Monday and find out part number and post. Figure its going to be $280 neighborhood.
I'm going to try and fish it through with Rope pulled out with old cable rather than take up floor. Wish me luck.
05-08-2011, 02:41 PM #6
If I remember correctly the cable was zip tied to some wiring in a few place-reason to pull the floor up.
13 Mobius LSV-sold
08 Mobius LSV-sold
03 Mobius LSV-sold
