Results 1 to 10 of 12
Thread: Gelcoat damage
    Sep 2010
    Okotoks, Alberta
    Default Gelcoat damage
    Owners manual says leaving boat in water for extended periods can damage gelcoat.
    My question is how long can you leave it in before you need to worry?
    Last year I pulled it out every two weeks for a night, seems ok can I leave it in longer?
    2008 Outback DD
    Thanks!
    Sep 2010
    Lighthouse Point, FL
    I would strongly question that comment w SC. I know of boats that stay in the water for YEARS and never have a gel coat issue. Do you think people w big sport cruisers or yachts pull their boats???
    Just my .02
    REALLY????
    Sep 2010
    Lake wallenpaupack PA
    Quote Originally Posted by 11 Outback V View Post
    Just my .02
    most of those boats have ablative paints on them.
    if your gelcoat has scratches or gouges into the fiberglass then over time the glass can soak up the water..... if you have a clean hull i dont think you need to worry....
    Sep 2010
    /\ /\ /\ Really????
    please enlighten me as to how fiberglass will "soak up water"
    REALLY????
    Apr 2008
    California
    They do soak up water, It's called osmostic blistering, read about it here.
    ANY fiberglass boat can get osmotic blisters. The longer it sits in the water the greater chance of it happening. Mastercraft had a couple of years where their boats were getting it bad. Saw one myself and it had hundreds of blisters the size of a nickel or smaller. Push hard on one and water would burst out!
    I personally don't worry about it for a week while camping, but any longer than that i would worry, especially after seeing a few cases and what it takes to repair.
    May 2008
    Minneapolis
    in like 04 I believe they had a problem with their glass one my buddy went to look at had this happen to it
    2007 Outback V
    Sep 2010
    /\ /\ /\ Really????
    click here and learn
    http://lmgtfy.com/?q=does+fiberglass...+soak+up+water
    this brings back the worry of water trapped below the ski locker...if water causes blistering in fiberglass over time will this compromise the structural integrity of the fiberglass? this goes back to the design flaw in all 08 to 02 lsvs or whatever year it affects
    Henderson, NV
    I remember that mastercraft issue and seems that one guy had a pretty well designed website calling them out on what they would not do to fix the issues on his mc.
    I would think tho that it is the exception not the rule as you look at the thousands upon thousands of boats sitting in the marinas around the country and those that live on lakes that leave their boats at docks 24/7.
    Sep 2010
    Okotoks, Alberta
    I'm hoping that it is the exception rather than the rule, but I have heard of it happening (the gelcoat blistering) and the owners manual does not recommend leaving our non treated gelcoat in the water for extended periods.
    Just wondering what 'extended' is defined as?
