Results 1 to 10 of 13
Thread: water pump part #
04-28-2011, 03:32 PM #1
water pump part #
have to replace the water pump on my 04 outback, does anyone know the part number?
04-28-2011, 03:41 PM #2
There are many water pumps in our boats.
What pump do you need to replace?2008 Outback V - gravity III ballasts, perfect pass star gazer, hydraulic wake plate, depth finder, water stainer, rad-a-cage tower, board racks, tower mirror, bimini top, audio package d, graphics package e, appearance package, cockpit & tonneau cover, mooring cover, black stainless rubrail, docking lights, OJ 14.25x14.0 prop.
04-28-2011, 05:25 PM #3
The raw water impellar part # is Johnson 812B. Hope this helps.
04 LSV
04-28-2011, 07:42 PM #4
the water pump its self cause its spraying out water like a little stream when i run the boat..comes right out the pump infront of the belt
04-29-2011, 08:47 AM #5
Check this site out buddy.
http://www.marineexhaustmanifolds.co...-and-parts.htm
Im assuming you mean the actual main engine water pump.
http://www.marineexhaustmanifolds.co...ting-pumps.htm
Eighter way this site has it all man.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
05-01-2011, 12:35 AM #6
Well I just hooked a hose up to the inlet on that little plastic piece ( i don know what it's called sorry) in-between one of the rubber hoses and that's cracked and has a nice flow spraying out.. Anyone know what's it called and where ican get one.. Starting to figure out that I bought a boat someone decided to take out in salt water cause my speaker wires and light wires going to the tower are toast too ( boat was originally from Florida then someone brought it to tennesee and then I bought it and brought it to new York)
05-01-2011, 02:08 PM #7
this plastic piece is leakin like crazy when i hooked the hose up so does anyone know where i can get one?
05-02-2011, 11:29 AM #8
I just cant tell what im looking at in that pic maybe a couple taken from father back or something.
[COLOR="#696969"]
05-03-2011, 02:43 AM #9
ounds good..ill take some more in the morning..if ur standing in the boat looking at the bow its on the left side of the motor
05-03-2011, 09:33 AM #10
Hey Moto thats a Perko flush valve. You will need to measure the i.d. of the hose to know what size you need. Most boating supply stores are Perko dealers. If you need more help let us know.Do you realize that in your pic only one side of the valve is connected?
04 LSV
