Results 1 to 10 of 11
Thread: LS rear ballast mod question
04-22-2011, 03:31 PM #1
Has anyone ever or heard of anyone taking out the hard tank ballast under the rear seat in an LS and replacing it with a Fatsac? I was thinking about it last night I'm pretty sure a W705 (650lb) sac would fit in there. What do you all think? If so would it connect to the factory pump and lines or would I have to buy an adapter or something like that?
Skate: LF Faction 44
Surf: LF Custom Quad & XXX
Tow Rig:
04-22-2011, 03:52 PM #2
On my '08 LS the rear seat is supported by the hard ballast tank, but it is a different hull then '05 LS. Some of the earlier LS had a 2 position rear seat if yours is one of them I believe the larger bag is not a problem. If yours is like mine you would need modify the supports for the rear seat or not use the rear seat when you plan to fill the sac.
Patrick
5 light- light bar. 2015 RAM 3500HD Dually 6.7 Diesel w/ Aisin 6 speed tranny
Live life today!
04-22-2011, 04:31 PM #3
Ok thanks. I will check and see how the seat is supported. I'm not quite sure if the seat actually sits on the tank or not. It might...
Tow Rig:
04-28-2011, 04:33 PM #4
Yep, the Hard Tank supports the seat. I guess that won't work unless I get some creative ingenuity and build something.
Tow Rig:
04-28-2011, 07:44 PM #5
It would take some major modifing to get a larger soft sac under the seat. The gas tank rest directly behind the hard ballast tank so there is no room to go back only up. And the '08 LS the rear seat is a major pain to pull out, I have actually broke one of my speakers taking in and out, because of how it is wedged into its spot.
Are you trying to get a bigger wake to surf or wakeboard?
I have noticed with my boat the best wakeboarding wake is with the ballast empty and gas tank full. The wake is stiffer and has a better lip, but as the gas tank empties filling the hard ballast with equal amount of water keeps the wake consistant. If you fill the ballast tank when gas tank is full the wake gets soft and it is hard to get lift with the wake board.
For skiing the best wake (flat) is when gas tank is almost emty and of coarse no ballast.
Now surfing I am still trying to figure the wake out. I just started surfing this season and the hard ballast just isn't enough. The sweet spot is so close to the swim platform that you are actually riding almost against it. But I ordered 2 750lbs sacs that just came this week and we are going to try them out this weekend.Patrick
Live life today!
04-28-2011, 07:52 PM #6
I found the best wake for surfing is not to put any ballast in the front and fill the side that you are going to be surfing. I usually have a few people in the boat when surfing so we try and get them to the surf side and it usually works great. If you put one of the 750 behind the driver it will probably give you a good wake.
07 Mobius LS--Razorback Red
04-30-2011, 01:15 AM #7Senior Member
- Jun 2006
- 194
harmsway
You need to put more weight up front to get your wake firmer. Especially with your rear ballast full and gas tank full. Do you have a wake plate and if so where do you run it?
04-30-2011, 12:40 PM #8
I don't have a wake plate, but that is one of the #1 upgrades for this winter coming up. I do have 2 750lbs sacs to play around with I just haven't had a chance to get out with them. I am fixing to hit the water today and try them out. It seems that there is a lot of different perference of what will make a good wake. Of course if you are not comparing the same hull and driveline set up this is going to make a big difference in what needs to be done to make a good wake.
Patrick
Live life today!
04-30-2011, 09:49 PM #9Patrick
Live life today!
04-30-2011, 10:10 PM #10Senior Member
- Feb 2008
- 164
Harmsway, that wave looks great. How many People did you have in the boat with ya today? Do you think you will use your other 750 sack? Do you think you would benefit from putting some weight up front?
Chad
